2944
Highlighted
1141 upgrade to Light Weight??
I wonder if there is a different method to upgrade a AP1141 to Light Weight mode than the one for a/b/g APs?
I was following normal process but Upgrade Tool sent a message saying "AP IP ADDRESS not supported by upgrade tool"
Any comments?
Regards!
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Hall of Fame Community Legend
Re: 1141 upgrade to Light Weight??
the datasheet tels us tha tthe minimum software required is 7.0
The data sheet is incorrect.  I've used 1140 in 6.X because it's the same "level" where OfficeExtend works.
Thumps Up Leo!! some how we need to follow the datasheets.. but i will contact the doc team and try to get this fixed.. i hv seen the 1140 in 5.2 as well!!
Surendra
Surendra BG
16 REPLIES 16
Hi Rguzman,
The TOOL is not supported for 1141 APs since the comes with the inbuilt certificates that is (manufacture installed certs) in all newer APs, in older APs the TOOL will generate the Certs on the AP.
Here is the first method..
Method 1
Download TFTPd32 server on your laptop and install it (its a free ware available in Google)
here is the steps..
1>> Download the tftpd32.exe and run it and install it.
2>> Download the latest image for 1141 AP from Cisco.com
3>> Point the image in the TFTP server by browsing..
4>> Make sure the hidden folder options is unchedked in folder options..
5>>  Now connect a Console cable and the ethernet port from the AP to your  laptop.. assign the ip on you laptop and the BVI in the same subnet..
6>> make sure we are able to ping each other (from the PC to AP and from AP to PC)..
7>> Now issue the command
archive download-sw /force-reload /overwrite tftp:///
ex
archive download-sw /force-reload /overwrite tftp://192.168.1.1/c1140-rcvk9w8-tar.124-21a.JA2.tar
This will do it for you!!
Lemme know if this answered your question..
Surendra
Please dont forget to rate the usefull posts..
Surendra BG
Hi Surendra,
Thanks for posting.
I followed the steps and it seems it worked since it is trying to find the WLC except that it sent the next log:
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Dec  6 11:16:22.596: %LWAPP-3-CLIENTERRORLOG:  Retransmission count for type (IMAGE_DATA) exceeded more than max(1)
*Dec  6 11:16:22.596: %LWAPP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Dec  6 11:16:22.596: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Dec  6 11:16:22.601: %LWAPP-3-CLIENTERRORLOG: not receive read response(5)
*Dec  6 11:16:22.601: Image could not be downloaded: LWAPP goes back to discovery
*Dec  6 11:16:22.607: lwapp_image_proc: unable to open tar file
*Dec  6 11:16:22.608: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Dec  6 11:16:22.609: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Dec  6 11:16:22.611: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Dec  6 11:16:22.615: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Dec  6 11:16:22.615: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Dec  6 11:16:32.615: %CAPWAP-3-ERRORLOG: Go join a lwapp controller
*Dec  6 11:16:32.615: %LWAPP-3-CLIENTERRORLOG: Set Transport AddressCalled
examining image...
Loading file /c1140...
*Dec  6 11:16:32.623: %LWAPP-5-CHANGED: CAPWAP changed state to JOIN
*Dec  6 11:16:16.592: %LWAPP-5-CHANGED: CAPWAP changed state to IMAGE
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
%Error opening lwapp:/c1140 (Incorrect Login/Password)
archive download: takes 6 seconds
Also these are the logs in th WLC:
Dec 06 11:23:55.514 spam_lrad.c:3114 LWAPP-3-DECRYPT_ERR: Unable to decrypt image data message; AP 1c:df:0f:94:93:3b
Dec 06 11:23:55.514 spam_crypto.c:707 LWAPP-3-DECRYPT_ERR: Unable to decrypt LWAPP packet; AP 1c:df:0f:94:93:3b
Dec 06 11:23:55.513 spam_crypto.c:289 LWAPP-3-DECRYPT_ERR5: Error decrypting packet (using old key) from AP 1c:df:0f:94:93:3b (session identifier 666a2138)
This is the image I used: c1140-rcvk9w8-tar.124-21a.JA2.tar
Hi Rguzman,
Whats the WLC software version that you are running?? the datasheet tels us tha tthe minimum software required is 7.0
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502793.html
leme know if thes answered your question..
Surendra
Please dont forget to rate the post if this answered your question
Surendra BG
Surendra
Surendra BG
Good luck!  I've given up all hopes asking someone to update very out-dated or incorrect Cisco documents.
i will take care of this!!
have a great day Leo..
Surendra
Surendra BG
Hey Surendra,
Can you PM me the email addresses to whom do I send request for documentations to be updated?
i need to raise a documentation bug for this.. so its confedential
Surendra
Surendra BG
ok
Surendra BG
Thank you very much.
here is the second method..
http://www.cisco.com/en/US/docs/wireless/access_point/12.2_13_JA/configuration/guide/s13trb_ps4570_TSD_Products_Configuration_Guide_Chapter.html#wp1038660
make sure you replace the Autonomous Image with the LWAPP recovery image..
lemme know if this answered your question..
Surendra
Surendra BG
Content for Community-Ad
August's Community Spotlight Awards
