1522 Outdoor Access Point Clarification
ciscokid7181
Dear Folks,
One of our client requires Outdoor Access Points across the campus, UTP outdoor cable would be provided.
I would like to clarify the following points
1. Does the Standard model 1522 Access Point support POE that can take direct from POE Switch or is POE injector mandatory ?
2. Is mounting kit included or ordered extra ?
Appreciate your kind help and support .
SID
Leo Laohoo
Outdoor APs require injectors.
Leo Laohoo
If i purchase this unit, does it come along with the power cable and adaptor ? As i dont see in the configurator / datasheet , i assume it is built in .
SID
You can find the part numbers here:
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1130-ag-series/product_data_sheet0900aecd8066a157.html
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
Typically you would hard wire the power to the units that are considered MAP's, or the AC adapter.  The RAP's typically would have a power injector to power that unit up.
Scotty
-Scott
