511
Beginner
1602 APs fail to join 7500 controller after update
I have two 1602 APs that are doing the same thing.  They initially join the 7500 controller, download the needed software, but after they reboot, they fail to re-join.  Here is the log info from one of the APs:
*Apr 22 23:36:17.067: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Apr 22 23:36:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.6.60 peer_port: 5246
*Apr 22 23:36:19.183: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:929 Unexpected message received while expecting HelloVerifyRequest
*Apr 22 23:36:19.183: %DTLS-5-SEND_ALERT: Send FATAL : Unexpected message Alert to "WLC IP ADDRESS REMOVED FOR PRIVACY REASONS"
*Apr 22 23:36:19.183: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to "WLC IP ADDRESS REMOVED FOR PRIVACY REASONS"
*Apr 22 23:37:22.067: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Apr 22 23:37:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.1.6.60 peer_port: 5246
*Apr 22 23:37:28.571: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_record.c:394 BD is not of DTLS Change Cipher Spec type
*Apr 22 23:37:28.571: %DTLS-5-SEND_ALERT: Send FATAL : Internal error Alert to "WLC IP ADDRESS REMOVED FOR PRIVACY REASONS"
*Apr 22 23:37:28.571: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to "WLC IP ADDRESS REMOVED FOR PRIVACY REASONS"
Everyone's tags (2)
25 REPLIES 25
Participant
Re: 1602 APs fail to join 7500 controller after update
What version of code are you running on the 7500 and can you also provide a debug output on the wlc:
debug capwap errors
debug capwap events
Beginner
Here is the code: 8.3.143.4
I have enabled those two debug commands on the WLC.  How can I view the output?  I assume it will need to be filtered by the APs in question (there are over 1,000 APs on this controller)
VIP Mentor
paste the output of these commands:
sh version from AP
sh sysinfo (or country code configured on WLC)
Boot-up process from AP console.
Also check the date and time on cisco WLC.
Dont forget to rate helpful posts
Beginner
Date and time on WLC
show time
Time............................................. Wed May 8 10:04:56 2019
Below are the country codes on the WLC.  The two APs are physically located in Brazil (BR):
AR, BO, BR, CA, CL, CO, CR, DO, EC, JM, MX, PA, PE, PR, PY, US, UY, VE
I will have to arrange console to run the sh version, and sysinfo. However, the software loaded is: ap1g2-k9w8-tar.153-3.JF9.tar
Thanks.
Hall of Fame Community Legend
Look at the time and date of the AP.
See if the WLC has NTP configured.
Beginner
We do have NTP configured, although it says "AUTH DISABLED".
So basically the time and date on the AP need to match that of the WLC? I wonder why I haven't had to do that before. We have hundreds of 1600s that work fine.
Highlighted
If NTP is configured, post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time; and
3. AP: sh version
Beginner
show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.143.4
RTOS Version..................................... 8.3.143.4
Bootloader Version............................... 8.1.102.0
Emergency Image Version.......................... 8.1.102.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... hidden
System Location.................................. hidden
System Contact................................... hidden
System ObjectID.................................. hidden
Redundancy Mode.................................. SSO
IP Address....................................... hidden
IPv6 Address..................................... ::
System Up Time................................... 153 days 3 hrs 1 mins 35 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
System Stats Realtime Interval................... 5
--More or (q)uit current module or <ctrl-z> to abort
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries : AR,BO,BR,CA,CL,CO,CR,DO,EC,JM,
............................................... MX,PA,PE,PR,PY,US,UY,VE
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +24 C
Fan Status....................................... OK
                                                    RAID Volume Status
Drive 0.......................................... Good
Drive 1.......................................... Good
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 9
Number of Active Clients......................... 3584
OUI Classification Failure Count................. 117045861
Burned-in MAC Address............................ 64:9E:F3:65:74:60
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 6000
System Nas-Id.................................... hidden
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
show time
Time............................................. Wed May  8 10:51:00 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT -5:00) Eastern Time (US and Canada)
NTP Servers
    NTP Polling Interval.........................     3600
     Index     NTP Key Index                  NTP Server                Status          NTP Msg Auth Status
       1              0                                 hidden                              In Progress          AUTH DISABLED
sh ver
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Experimental Version 15.3(201        80904:192853) [vipendya 130]
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 04-Sep-18 12:30 by vipendya
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFT        WARE (fc1)
"NAME HIDDEN" uptime is 17 hours, 56 minutes
System image file is "flash:/ap1g2-k9w8-mx.ap_smr4_esc.201809041149/ap1g2-k9w8-x        x.ap_"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1602I-T-K9 (PowerPC) processor (revision B0) with 187386K/74672K bytes of memory.
Processor board ID TSP1912AABU
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.143.4
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:F6:9D:C6:B4:67
Part Number                          : 73-14671-04
PCB Serial Number                    : TSP19080181
Top Assembly Part Number             : 800-38552-03
Top Assembly Serial Number           : TSP1912AABU
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP1602I-T-K9
Configuration register is 0xF
Beginner
Sorry double post.
"In Progress" = NTP not working
Are you able to reach the WLC IP from this AP ?
Try to ping the WLC IP and See, whether its reachable. Also see on the Monitor --> Statistics --> AP Join status of the WLC, are you getting hits for the AP.
Am suspecting this could be a reach-ability issue.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Beginner
Thanks. I will try to ping the WLC next time I have console access. However, it was able to join the controller fine the first time to download the software. It does have a hit in the AP join stats - Status not joined.
No, You can see the logs of AP, which fails to join the controller. If the reach-ability of the AP is there towards the WLC at-least you will get a hit on your WLC.
Check the reach-ability and logs on the controller.
Beginner
Ok I have console access now.  I can ping the WLC fine.
Content for Community-Ad
July's Community Spotlight Awards
