12-02-2015 06:10 PM - edited 07-05-2021 04:19 AM
At this point the only way that I can access the web console ( to make changes or manage) is to plug directly into the AP. I've tried plugging into the switch that the AP is connected, and tryied access the console via ip address, and get nothing. Is there a way thay I can access the management console via the network. These are standalone units without a WLC.
12-02-2015 06:14 PM
The AP on an access vlan? If on a trunk port, you need to make sure the AP management is on the native vlan. I don't see why you would have an issue if the AP is on vlan x on an access port and your laptop on the same vlan x.
-Scott
12-02-2015 06:27 PM
It is on a Trunk port on the switch. . I didn't know that you could assign the management to a different vlan. Am I able to access the management via wireless, or must I be wired.
12-02-2015 06:32 PM
The AP management needs to be the native vlan. If not, then your never going to access the AP.
-Scott
12-02-2015 06:38 PM
Thanks so much for your help.
12-03-2015 05:48 AM
Did that work for you? Or are you still having issues connecting when in the network?
-Scott
12-03-2015 06:03 AM
I had to leave, I am a volunteer at our Church and it is for them that I am doing this. I've read the links which helped alot. I'll let you know should there be any complications. You've been very helpful, thanks again.
I won't be able to get there to do this until Saturday.
12-03-2015 06:45 AM
Cool. Keep us posted.
-Scott
12-02-2015 06:34 PM
You might want to reference this link:
https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
Hope this helps
-Scott
