318
1832i ME not joining controller
Hello
I have a 3800 running as a ME and its running as a controller, which works fine.  I have added additional 1832i which is converted and image is matching that of 3800.  To power the 1832i i am using the AIR-PWR-C= but it won't join the controller.
I keep getting "Max retransmission count exceeded, going back to DISCOVER mode."  I am not sure what i am doing wrong, any help would be great. Thanks
Processor board ID KWC193206CW
AP Running Image : 8.5.151.0
Primary Boot Image : 8.5.151.0
Backup Boot Image : 8.9.111.0
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
2 Gigabit Ethernet interfaces
[*08/21/2019 03:06:45.1699] CAPWAP State: Image Data
[*08/21/2019 03:06:45.2199] do NO_UPGRADE, part1 is active part
[*08/21/2019 03:06:45.2199] CAPWAP State: Configure
[*08/21/2019 03:06:45.2299] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect
[*08/21/2019 03:06:45.2299] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect
[*08/21/2019 03:06:48.0390] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/21/2019 03:06:50.8882] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/21/2019 03:06:53.7373] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/21/2019 03:06:56.5864] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/21/2019 03:06:59.4355] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/21/2019 03:07:02.2846] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*08/21/2019 03:07:02.2846] Max retransmission count exceeded, going back to DISCOVER mode.
[*08/21/2019 03:07:02.2946]
[*08/21/2019 03:07:02.2946] CAPWAP State: DTLS Teardown
[*08/21/2019 03:07:07.1531] Discovery Response from 192.168.1.150
[*08/21/2019 03:07:16.0000]
[*08/21/2019 03:07:16.0000] CAPWAP State: DTLS Setup
[*08/21/2019 03:07:16.0599]
[*08/21/2019 03:07:16.0599] CAPWAP State: Join
[*08/21/2019 03:07:16.0599] Sending Join request to 192.168.1.150 through port 5256
[*08/21/2019 03:07:16.0699] Join Response from 192.168.1.150
[*08/21/2019 03:07:16.1799]
[*08/21/2019 03:07:16.1799] CAPWAP State: Image Data
[*08/21/2019 03:07:16.2299] do NO_UPGRADE, part1 is active part
1 ACCEPTED SOLUTION
VIP Mentor
Re: 1832i ME not joining controller
Here are my answers:
1. yes
2. Yes it will work if you both APs (ME WLC and 1832 ap)in same domain.
3. -B and -A domain belongs to USA thats the reason both working together.
4. Canada regulatory domain must be -A. If you use -S domain in canda then its not legel and it will not work.
Dont forget to rate helpful posts
12 REPLIES 12
VIP Mentor
paste the show version command output from both APs (ME controller and 1832I)
was 1832i  AP connected to another WLC before ?
AP:
AP80E8.6FD8.4208#show version
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
--More-- [*08/21/2019 05:15:41.5864] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Cisco AP Software, (ap1g4), C1832, RELEASE SOFTWARE
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu Jun 13 23:49:47 PDT 2019
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 30
AP80E8.6FD8.4208 uptime is 0 days, 0 hours, 2 minutes
Last reload time : Wed Aug 21 02:47:08 UTC 2019
Last reload reason : unknown
cisco AIR-AP1832I-S-K9 ARMv7 Processor rev 0 (v7l) with 997268/705212K bytes of memory.
2 802.11 Radios
Radio FW version : f6d58b5e05c762162e07fe70e0671647
NSS FW version : NSS.AK.C.CS-3-fix3
Base ethernet MAC Address : 80:E8:6F:D8:42:08
Part Number : 0-0000-00
PCA Assembly Number : 074-104313-01
PCA Revision Number : 01
PCB Serial Number : KWC193206CW
Top Assembly Part Number : 000-00000-00
Top Assembly Serial Number : KWC193206CW
Top Revision Number : A0
Product/Model Number : AIR-AP1832I-S-K9
Controller:
(Cisco Controller) show>sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.151.0
System Name...................................... Suleman
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2373
IP Address....................................... 192.168.1.150
Last Reset....................................... 0: unknown
System Up Time................................... 8 days 6 hrs 30 mins 26 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Highlighted
VIP Mentor
also paste the show version output from ME controller(3800).
VIP Mentor
AP(1832) is with -S domain which is not correct and you are running US as country code on WLC.
To connect to US coutnry code wlc you must AP with -B domain.
Edit: -S domain is used for Brunei, Hongcong, ..etc
So the AP needs to be "B" in it? instead of S
My 3800 has "B" in the model number and i have 2800 which are "A"
VIP Mentor
AIR-AP1832I-S-K9
This AP has -S domain, whcih will not comatibile with 3800 (-B) domain. It will not work.
More info about wireless compliance status..
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Thank you for reply so in summary i need to match Domain of AP with Domain of controller? Could you please answer my question below.
1. Since my AP Controller is B and this AP is S, is this why its mismatch?
2. What if i make the -S domain the controller and have the other -S AP join this controller, will that work? and i totally remove 3800 from network?
3. How come i can connect AP Controller B (3800) and 2802-A and they both work together?
4. If i am trying to make these work in Canada with 3 x 1832 all 3 with -S domain will that work in Canada? If controller is hosted on one of the 1832?
VIP Mentor
1. yes
Thank you for that.
2. So what prevents me from changing the domain on the ME controller to that of -S to match AP? i just tried that and its working
My speed is running great on all my devices except the iPhone X and Apple Tv, i can't seem to get more than 50mb while other devices are getting 400mb on wifi, connecting to same AP. Anything to check here?
Content for Community-Ad
August's Community Spotlight Awards
