02-23-2011 09:03 AM - edited 07-03-2021 07:51 PM
I am new to this
intergrated router and AP. I followed the basic config and have it working. I can get to any network from wireless or wired lan to internet.
Now i want to setup a VLAN for the wireless side that can not get the the wired lan, just out to the internet.
I tryed a few things but I just dont understand the config well to to this.
can someone post a config?
Solved! Go to Solution.
02-23-2011 12:44 PM
Currently, is your wireless network having a separate subnet from your wired network ?
If yes, you only need to configure a simple access list. (to help you, give us your network ranges)
If not, then you must start by giving them separate subnets.
You can in any case post your router config and we'll tell you what to modify.
Nicolas
02-23-2011 12:44 PM
Nicolas
02-24-2011 05:39 AM
Yes they are on the same subnet.
I will change that, thanks.
04-27-2011 05:53 PM
I have set up my 1941w in the same way as what you are trying.
Look for my posts "working 1941w config" as I have attached a full working config with access control lists applied to the VLANS assigned to the wireless AP's.
This example should help you finish off your config.
John.
