Highlighted
2.4 GHz Directional Antenna for Cisco 1524 AP
Does Cisco have a Directional antenna at 2.4 GHz for the outdoor aironet Cisco 1524 AP?
5 REPLIES 5
Highlighted
VIP Mentor
HI Mohammed,
As per my knowledge:
1524 AP with 2.4 GHz , u can use :
AIR-ANT2410Y-R
Indoor/outdoor directional antenna for use with access points or bridges
Hope it helps.
Highlighted
Hello Sandeep,
The AIR-ANT2410 has a single N-Type connector, where as since the 1524 AP has the diversity option. is there a way we can use this antenna? Your input on this will be very helpful for me
Highlighted
HI Mohammed,
I never used this kind of anteena.You must ask this question with your supplier or any cisco hardware experet guys.
http://www.secureitstore.com/Aironet-Antennas-Accessories.asp
Highlighted
Hall of Fame Master
Here is a list of antennas for the 1520's
http://www.cisco.com/en/US/docs/wireless/access_point/1520/installation/guide/1520_ch1.html#wp1069566
-Scott
Highlighted
The Cisco Aironet 1522 Lightweight Outdoor Mesh Access Point is a  dual-radio system with dual-band radios that are compliant with IEEE  802.11a (5-GHz) and 802.11b/g standards (2.4-GHz). Where service  providers have already invested in a broadband cable network, the Cisco  mesh can seamlessly extend network connectivity with the Cisco Aironet  1522CV access point, by connecting to its integrated cable modem  backhaul (DOCSIS 2.0). Designed for the most demanding environments, the  Cisco Aironet 1522HZ has been classified for hazardous locations (Class  1, Zone 2/Div 2) such as petroleum refineries and utility gas plants.
Content for Community-Ad
