11-19-2013 01:56 AM - edited 07-04-2021 01:17 AM
Does Cisco have a Directional antenna at 2.4 GHz for the outdoor aironet Cisco 1524 AP?
11-19-2013 04:06 AM
HI Mohammed,
As per my knowledge:
1524 AP with 2.4 GHz , u can use :
AIR-ANT2410Y-R
Indoor/outdoor directional antenna for use with access points or bridges
Hope it helps.
11-19-2013 11:09 PM
Hello Sandeep,
The AIR-ANT2410 has a single N-Type connector, where as since the 1524 AP has the diversity option. is there a way we can use this antenna? Your input on this will be very helpful for me
11-20-2013 12:13 AM
HI Mohammed,
I never used this kind of anteena.You must ask this question with your supplier or any cisco hardware experet guys.
http://www.secureitstore.com/Aironet-Antennas-Accessories.asp
11-19-2013 04:47 AM
Here is a list of antennas for the 1520's
http://www.cisco.com/en/US/docs/wireless/access_point/1520/installation/guide/1520_ch1.html#wp1069566
11-21-2013 09:56 AM
The Cisco Aironet 1522 Lightweight Outdoor Mesh Access Point is a dual-radio system with dual-band radios that are compliant with IEEE 802.11a (5-GHz) and 802.11b/g standards (2.4-GHz). Where service providers have already invested in a broadband cable network, the Cisco mesh can seamlessly extend network connectivity with the Cisco Aironet 1522CV access point, by connecting to its integrated cable modem backhaul (DOCSIS 2.0). Designed for the most demanding environments, the Cisco Aironet 1522HZ has been classified for hazardous locations (Class 1, Zone 2/Div 2) such as petroleum refineries and utility gas plants.
