05-29-2015 12:37 PM - edited 07-05-2021 03:19 AM
I have over 100 * WLC 2504s that will all need different adder license counts applied. Staging will be configuring the WLCs before sending out to remote sites.
How can the adder licenses be staged before sending out? Through console?
05-29-2015 03:57 PM
Traditional method is using console or GUI.
If you know scripting then you can automate this using SQL database. You have a DB of the S/N of the appliances and then you instruct the backend to remote into the appliances and apply the license adder you've specified in the SQL database.
06-01-2015 05:14 AM
Thank you for your reply. I will investigate the scripting automation.
06-01-2015 07:51 PM
You need to open a TAC case for the same.
06-02-2015 04:49 AM
Thanks much. Opening TAC case and will update this discussion with findings.
