11-27-2012 08:02 PM - edited 07-03-2021 11:07 PM
Hello Everyone,
I have a cisco 2504 WLC with 4 Ap's connected to it, however is it possible to have a wired guest on lets say port 4? We sometimes have visitors and the WLC is easily accessable for us to plug in their computer, however i do not see the "Guest-Lan" check mark box on the interface. Please help, i have been trying to get this for 3 days now.
Thank you,
Andrew
Solved! Go to Solution.
11-27-2012 08:14 PM
No... the WLC shouldn't be used as a switch. If you want to have guest, you should just implement a wireless guest access and have them use that. You would need a 4400 or a 5508 to do wired guest.
11-27-2012 08:05 PM
The 2504 doesn't support wired guest access.
11-27-2012 08:09 PM
so there is NO way to plug in a computer into the available port and have it work?
11-27-2012 08:14 PM
