05-11-2015 04:19 PM - edited 07-05-2021 03:13 AM
When I issue the capwap ap hostname <name> command I get the error message ERROR!!! Command is disabled.
Why? I haven't changed default privilege levels.
Thank you.
Solved! Go to Solution.
05-12-2015 04:05 AM
05-11-2015 05:31 PM
The reason is because the ap has joined a WLC already. If you want to be able to use the command, you need to either delete the image from flash and just leave the rcv image or delete the private config from flash.
First, check the flash:
lap_1131#dir
Directory of flash:/
2 -rwx 279 May 09 2008 11:52:20 +00:00 env_vars
4 -rwx 6168 May 09 2008 11:52:20 +00:00 private-multiple-fs
6 drwx 256 May 09 2008 11:49:05 +00:00 c1130-k9w8-mx.124-3g.JA2
5 drwx 128 Mar 01 2002 00:03:43 +00:00 c1130-rcvk9w8-mx
15998976 bytes total (10716672 bytes free)
Then delete the LWAPP image:
lap_1131#delete /r /f flash:/c11310-k9w8-mx.124-3g.JA2
Not the one the has rcv in it!!!!!!
Thirdly reload the AP:
lap_1131#reload
Then issue a clear lwapp private-config
You'll end up with a clear AP.
Option 2 - If there in no rcv image
delete /r /f flash:private-multiple-fs
-Scott
05-11-2015 05:55 PM
Could be due to Cisco Bug ID: CSCtl96208
Workaround listed is to configure the hostname via the WLC.
05-12-2015 04:05 AM
05-12-2015 03:42 PM
Thank you!
05-13-2015 04:17 PM
Please refer to the below link :
https://supportforums.cisco.com/document/71531/how-assign-static-ip-lightweight-access-point-lap-1131ag-registering-controller-wlc
