08-10-2018 05:07 AM - edited 07-05-2021 08:58 AM
i have AIR-CAP2702I-E-K9 running as autonomous connected to Huawei HG8240T OPT
i configure DHCP pool on the AP then i disabled the DHPC from the huawei
i can get ip from the AP but no internet , i but the default router & DNS every thing should be fine but no internet , would you please help me
aaa session-id common
clock timezone +0200 2 0
no ip source-route
no ip cef
ip domain name bikoo.net
ip name-server 163.121.128.134
ip name-server 163.121.128.135
no ip dhcp conflict logging
ip dhcp excluded-address 10.10.10.1 10.10.10.5
ip dhcp pool BIKOO-AP
network 10.10.10.0 255.255.255.0
dns-server 163.121.128.134 163.121.128.135 10.10.10.1
default-router 10.10.10.1
dot11 pause-time 100
dot11 syslog
dot11 ssid BIKOO
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 xxxxxxxx
dot11 ssid RAFY
authentication open
guest-mode
no ids mfp client
dot11 arp-cache
no ipv6 cef
username Cisco privilege 15 password 7 xxxxxx
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid BIKOO
antenna gain 0
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
rts threshold 512
rts retries 128
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid RAFY
antenna gain 0
probe-response gratuitous
peakdetect
no dfs band block
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
packet retries 128
channel width 40-above
channel dfs
station-role root
rts threshold 512
rts retries 128
bridge-group 1
interface GigabitEthernet0
description ADSL LINK
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 7081.05ec.3747
ip address 10.10.10.2 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
length 0
transport input all
end
08-12-2018 10:08 AM
i don't have any switch this is wireless network only.
i tried to reset the AP also i tried to use the other site AP with no luck.
08-12-2018 10:16 AM
08-12-2018 10:19 AM
i just wonder why it's not going through the AP. any way thanks for your time and help.
08-12-2018 10:22 AM
I don't know either, because as long as you have your dns servers and your gateway configured right, that is all you need.
08-12-2018 10:24 AM
exactly , seems its from the hg8240T not the AP.
08-12-2018 10:29 AM
The thing is that the AP should be handing out address not the modem. So maybe the modem is only allowing access if the device uses dhcp from the modem.
08-12-2018 12:26 PM
i don't think i tried with D-Link DIR868L DHCP enabled and all the devices connected to the DLink get the ip from it with internet access normal.
12-08-2018 11:17 PM
Hello , i just figure it out if i start my DHCP pool from 10.10.10.5 the device's will take IP from the AP but no internet if i exclude the DHCP Pool from 10.10.10.1 10.10.10.128 any device will connect and get internet access !! that's very strange!!
so below 10.10.10.128 no internet !! above 128 there's internet !!
12-09-2018 08:42 AM
12-09-2018 10:01 PM
it's not an issue with the wireless, and for me it's okay to since i don't have full access to the HG8240T as it's blocked from the ISP side , so i'm okay with it since i manage to make the AP give IP's
Thank you everyone for your help and support
12-11-2018 02:01 PM
what if i need to give IP's to the wired client which is connected to the huawei lan ?
the setup is
Huawei . >> Cisco 2702i AP (DHCP)
i have synology connected the huawei but i can't get IP
