2702i not joining 9800-CL
Mikolaj Moryto
Because of some vWLC limitations I decided to test 9800-CL (16.11.1c) and after initial configuration I am stuck with AP not joining the controller. I followed all guides I could find and all discussions here I could find but nothing worked so far. Also tried to factory reset the AP with MODE button and clearing AP with following command:
delete flash:private-multiple-fs
clear capwap private-multiple-fs
As I want to migrate AP from vWLC to 9800 before factory resetting the AP I also tried to disable SSC and set authentication token on AP (through vWLC) and also on the 9800 side. That didn't work either.
Initial configuration completed:
- access (passwords, SSH, etc.)
- interfaces
- AP country
- wireless management interface
- wireless config vwlc-ssc key-size 2048 signature-algo sha256 password 0 <pwd>
AP (DHCP - 192.168.1.8):
*Sep  8 21:31:35.003: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Sep  8 21:31:35.015: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Sep  8 21:31:45.015: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
*Sep  8 21:31:45.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.151 peer_port: 5246
*Sep  8 21:31:45.000: DTLS_CLIENT_EVENT: dtls_connectionDB_add_connection: Added Connection 0x57FC158 Server 192.168.1.151:147E, Client 192.168.1.8:2531
*Sep  8 21:31:45.000: DTLS_CLIENT_EVENT: dtls_process_HelloVerifyRequest: Processing...
 dtls_process_HelloVerifyRequest: cookie_len = 20
*Sep  8 21:31:45.003: DTLS_CLIENT_EVENT: dtls_process_ServerHello: Processing...
*Sep  8 21:31:45.003: DTLS_CLIENT_EVENT: dtls_connection_set_cipher: Setting cipher to TLS_RSA_WITH_AES_128_CBC_SHA
*Sep  8 21:31:45.003: DTLS_CLIENT_EVENT: dtls_connection_is_resumed_session:
DTLS connection database is initialized
*Sep  8 21:31:45.003: DTLS_CLIENT_EVENT: dtls_process_Certificate: Processing...
*Sep  8 21:31:45.023: DTLS_CLIENT_EVENT: wtpDtlsCallback: Certificate verified ok!
*Sep  8 21:31:45.023: DTLS_CLIENT_EVENT: dtls_process_CertificateRequest: Processingt...
*Sep  8 21:31:45.023: DTLS_CLIENT_EVENT: dtls_process_ServerHelloDone: Processing...
*Sep  8 21:31:45.023: DTLS_CLIENT_EVENT: wtpDtlsCallback: Certificate installed for PKI based authentication.
*Sep  8 21:31:45.023: DTLS_CLIENT_EVENT: dtls_send_Certificate: Sending 1 certificates
*Sep  8 21:31:45.023: DTLS_CLIENT_EVENT: dtls_handshake_fragment_and_send: Re-aligning the last fragmenti by 1
*Sep  8 21:31:45.219: DTLS_CLIENT_EVENT: dtls_connection_is_resumed_session:
*Sep  8 21:31:45.219: DTLS_CLIENT_EVENT: dtls_prf: Called...
*Sep  8 21:31:45.231: DTLS_CLIENT_EVENT: dtls_connection_is_resumed_session:
*Sep  8 21:31:45.231: DTLS_CLIENT_EVENT: dtls_process_Finished: Processing...
*Sep  8 21:31:45.231: DTLS_CLIENT_EVENT: dtls_prf: Called...
*Sep  8 21:31:45.231: DTLS_CLIENT_EVENT: dtls_connection_established: Connection established!
*Sep  8 21:31:45.231: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.151 peer_port: 5246
*Sep  8 21:31:45.231: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.151
*Sep  8 21:31:45.231: DTLS_CLIENT_EVENT: wtpDtlsCallback: DTLS-Ctrl Connection 0x57FC158 established
*Sep  8 21:31:50.231: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.151
9800-CL (static - 192.168.1.151):
Sep  8 21:31:45.592: %CAPWAPAC_SMGR_TRACE_MESSAGE-3-EWLC_GEN_ERR: Chassis 1 R0/0: wncd: Error in Session-IP:192.168.1.8[9521] CAPWAP DTLS session closed for AP, cause: DTLS handshake error
2019/09/08 21:05:55.067 {wncd_x_R0-0}{1}: [capwapac-smgr-srvr] [23645]: (ERR): Unknown message type from load balancer, dropping
2019/09/08 21:05:55.084 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  IP:192.168.1.8[9521], Discovery Request received
2019/09/08 21:05:55.097 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  IP:192.168.1.8[9521], Discovery Response sent
2019/09/08 21:05:55.097 {wncmgrd_R0-0}{1}: [ewlc-infra-evq] [23098]: (debug): instance :0 port:11585MAC: 4b39.0001.000b
2019/09/08 21:05:55.097 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  Source IP:192.168.1.8[9521], Discovery handling completed for AP.
2019/09/08 21:05:55.097 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  IP:192.168.1.8[9521], Discovery Request received
2019/09/08 21:05:55.098 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  IP:192.168.1.8[9521], Discovery Request received
2019/09/08 21:05:55.098 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  IP:192.168.1.8[9521], Discovery Response sent
2019/09/08 21:05:55.098 {wncmgrd_R0-0}{1}: [ewlc-infra-evq] [23098]: (debug): instance :0 port:11585MAC: 4b39.0001.000b
2019/09/08 21:05:55.098 {wncmgrd_R0-0}{1}: [capwapac-srvr] [23098]: (info): MAC: 80e0.1d92.530c  Source IP:192.168.1.8[9521], Discovery handling completed for AP.
2019/09/08 21:06:05.082 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 22, handshake
2019/09/08 21:06:05.082 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS client hello
2019/09/08 21:06:05.083 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 22, handshake
2019/09/08 21:06:05.083 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS client hello
2019/09/08 21:06:05.084 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 22, handshake
2019/09/08 21:06:05.084 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS client hello
2019/09/08 21:06:05.085 {wncd_x_R0-0}{1}: [capwapac-smgr-srvr] [23645]: (ERR): IPv4: 192.168.1.8Failed to Process DTLS Hello message from loadbalancer server
2019/09/08 21:06:05.303 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 22, handshake
2019/09/08 21:06:05.304 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 22, handshake
2019/09/08 21:06:05.304 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 0, unknown type
2019/09/08 21:06:05.305 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 22, handshake
2019/09/08 21:06:05.305 {wncd_x_R0-0}{1}: [ewlc-infra-evq] [23645]: (info): DTLS record type: 0, unknown type
2019/09/08 21:06:05.308 {wncd_x_R0-0}{1}: [ewlc-dtls-sessmgr] [23645]: (info): Remote Host: 192.168.1.8[9521] Completed cert verification, status:CERT_VALIDATE_SUCCESS
2019/09/08 21:06:05.314 {wncd_x_R0-0}{1}: [capwapac-smgr-sess-fsm] [23645]: (info): Session-IP: 192.168.1.8[9521] Mac:  Close CAPWAP DTLS session.
2019/09/08 21:06:05.314 {wncd_x_R0-0}{1}: [capwapac-smgr-sess-fsm] [23645]: (note): Session-IP: 192.168.1.8[9521] Mac:  Last Control Packet information not available.AP terminated in DTLS phase.
2019/09/08 21:06:05.314 {wncd_x_R0-0}{1}: [capwapac-smgr-sess-fsm] [23645]: (note): Session-IP: 192.168.1.8[9521] Mac:  Last Data Keep Alive Packet information not available.Data session was not established
2019/09/08 21:06:05.314 {wncd_x_R0-0}{1}: [apmgr-db] [23645]: (ERR): 80e0.1d92.530c Mismatch in session handles.Record already deleted and recreated
2019/09/08 21:06:10.312 {wncd_x_R0-0}{1}: [capwapac-smgr-srvr] [23645]: (ERR): Unknown message type from load balancer, dropping
Mikolaj
10 Replies 10
Sandeep Choudhary
please try this command on AP:
clear capwap ap all-config
Dont forget to rate helpful posts
Hi Sandeep,
Does the AP need to be in specific mode for that? I have it currently registered to vWLC and I have this:
When I was trying previously with recovery mode (MODE button) I had "clear capwap ap" command available but "all-config" was not there. There were only "clear capwap ap controller", "clear capwap ap ip" but not "clear capwap ap all-config".
first run this command:
debug capwap console cli
These two commands are not available now when the AP is registered to vWLC. Does it need to be factory reset? When I did the factory reset with MODE button for the last time I did not see "clear capwap ap all-config" there either.
you need to copy and paste the command on AP console.(Its a hidden command)
without this command you cant go in config mode.
That command worked after using "debug capwap console cli" but it did not solve the issue. I am still having the same "DTLS handshake" error on the controller side.
Hi @Mikolaj Moryto
Try whit  "erase /all nvram: " and reload the AP
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
So that wasn't really an AP or WLC configuration issue. Below commands were doing what they were supposed to.
erase /all nvram:
The reason for getting "DTLS handshake" error was because I misconfigured the interfaces and put all of them into single port group on ESXi side. Once changing it AP instantly registered to the WLC.
Thanks everyone for your assistance.
I'm noticing the same issue with a 9800-CL on ESXi...but I've verified that my interfaces are in different port groups.
Also, I've shut Gig1 on my 9800-CL.  Only using Gig2, and have it configured as a trunk.
I replied too soon - the command:
Fixed the issue for me.
Thanks!
