Community Helping Community
634
Beginner
2820i Mobility express LAG configuration
Hi all,
as per technote, if we want to configure LAG, 2820i is compatible with few cisco models only (3850/3650) etc.
Why is that so, isnt LAG = LACP?
6 REPLIES 6
VIP Advisor
Re: 2820i Mobility express LAG configuration
Hi @illusion_rox
Kinda is. Let's say it is a subset of real Link Aggregation as it does not allow you to select mode.
-If I helped you somehow, please, rate it as useful.-
Beginner
If the only issue is mode, it should still be compatible with 2960x series ? or any other 3rd party switch supporting LACP?
VIP Advisor
If you setup the switch to mode on, this should work.
Beginner
My confusion is, 2960x and 3650/3850 supports LACP. What does 3650/3850 supports in term of LAG that 2960x doesnt ?
LAG with 3rd party switches has not been tested. AP uses same IP address but different source port to do the balancing, so the switch should be able to do load balancing based on UDP port information. For more information on LAG with 3rd party switch please refer to bug CSCvf77787
Please refer:
https://techzone.cisco.com/t5/Access-Points/LAG-on-1800-2800-3800-AP/ta-p/1007165
**************** Please rate Useful posts********************
Highlighted
Beginner
Its not 3rd party problem. Cisco’s own 2960x series are not supporting LAG
Content for Community-Ad
August's Community Spotlight Awards
