3502i WLAN controller Software Version
I know that the 3502s as well as the 1262s need to terminate on a software release 7.0 or higher on the primary controller.
Now in the event that the primary controller has loaded release 7  and then you have a tunnel to an anchor controller across the WAN for guest access  and that controller is release 6.  Will this scenario work?
I would appreciate your responses.
Stephen Rodriguez
That should work, as the tunnel is just passing traffic and not terminating the AP.
In the guest access FAQ, there is a list of the supported anchor/foreign softwares.
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00809ba482.shtml#Q-Aug08
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
