10-15-2019 07:59 AM - edited 07-05-2021 11:09 AM
Can a 3560CX-8PC work with a AIR-AP3802P? AP will not power up.
Solved! Go to Solution.
10-15-2019 07:40 PM
10-16-2019 05:41 AM
Thank you for those that replied. I may have bad switch. I tried the AP on other 3560CX switches and the AP powered up. So I may need to RMA the switch that will not give the AP power
10-15-2019 02:55 PM
The data sheet of the 3560CX says it provides the required POE+ to the AP that it requires.
Have you tried all the mGig ports? Can you share show power inline from the switch
10-15-2019 07:40 PM
10-16-2019 05:41 AM
