Beginner
4 Regional WLCs and high availibility show command
I have setup a global solution with 174 APs spilt over 4 Regional WLCs and all is working properly but I need to double check some configuraiton like if each AP has the correct high avalibility setup. I can do that over the GUI but I woul like to loing to each Regional WLC and by command line do something like a show ap summary that includes the high availibilty config for each AP?
Anyone knows if this command exists.?
Thank you
Everyone's tags (6)
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Re: 4 Regional WLCs and high availibility show command
That information would show up in the sow run-config, but you would have to filter or just scroll to each of the ap's.  Or you can do a show ap config general .
-Scott
1 REPLY 1
Highlighted
Hall of Fame Master
-Scott
Content for Community-Ad
August's Community Spotlight Awards
