4 Regional WLCs and high availibility show command
p_perrotta
I have setup a global solution with 174 APs spilt over 4 Regional WLCs and all is working properly but I need to double check some configuraiton like if each AP has the correct high avalibility setup. I can do that over the GUI but I woul like to loing to each Regional WLC and by command line do something like a show ap summary that includes the high availibilty config for each AP?
Anyone knows if this command exists.?
Thank you
Scott Fella
That information would show up in the sow run-config, but you would have to filter or just scroll to each of the ap's.  Or you can do a show ap config general .
-Scott
Scott Fella
-Scott
