05-21-2015 07:24 AM - edited 07-05-2021 03:16 AM
05-21-2015 08:30 AM
Hi ,
The RRM's decision is based on the best power level.
However. Sometime we need to tweak manually.
During the "peak-client' time frame, get me the output "show run-config, show msglog and show traplog" from the WLC.
And mention the AP names near which 5 GHz radio is no seen.
Based on that, we can comment.
Victor
05-22-2015 04:30 AM
05-22-2015 05:08 AM
Hi Mal,
1) Log the SSH session to a text file.
2) Execute "Config paging disable"
3) Execute the commads
a) show run-config
b) show msglog
c) show traplog
4) Attach the text file to this thread.
Victor
05-22-2015 08:22 AM
05-21-2015 08:33 AM
If you get all the APs on power level 1, then we may run into the following problems.
a) it will create huge coverage overlap.
b) it will inturn trigger frequent/un-necessary client roaming.
c) Adjacent Channel interference.
So based on the outputs, we can decide on the power tweak.
Victor
