Community Helping Community
7471
Highlighted
Beginner
5 GHz vs. 2.4 GHz WLANs
I am preparing to set up guest wireless access in a dorm environment with a Cisco 5508 WLAN controller and Cisco 3602i APs.  According to the book I've been reading, it recommends that I set up a WLAN for 802.11a/n clients in the 5 GHz range and another WLAN for 802.11b/g clients in the 2.4 GHz range.  It recommends giving them an SSID like "Guest - 5GHz" and "Guest - 2.4 GHz" respectively.  Their reasoning is to allow the best experience for 802.11n users while still supporting legacy devices.  Is this a good idea, or should I simply set up a single WLAN for 802.11b/g/n on in the 2.4 GHz range until the 5GHz range has greater adoption?
4 ACCEPTED SOLUTIONS
Re: 5 GHz vs. 2.4 GHz WLANs
Hi Ryan,
For starters you can only bond on 5 ghz. What this means is that you will only get 300 meg on the 5 ghz side. On the 2.4 side you will get 144 at best, due to non bonding.
My stance is allow guest on both, so one 1 ssid. You wll get a mix of guest on 2.4 and 5 ghz. Unless there are compelling  reasons not to.
As for 5 Ghz and adoption, almost all new devices support 5 GHz and 802.11n. Dont be surprised if you see more guest on 5 GHz than 2.4.
Hall of Fame Master
I would just use one SSID, keeps the confusion level down. The only time I would restrict the guest wireless is if I have devices that utilize the 5ghz and that is when I would only allow guest on the 2.4ghz. Conserve my bandwidth per say. I have also disable 802.11N so the max a guest user could connect to is 54mbps, it really depends on your install and if its only guest that will be on your wireless.
-Scott
Hall of Fame Master
I would just use one SSID for guest. If you want guest to be on a different subnet than your management, then I would create a dynamic interface for guest and use that interface.
Sent from my iPhone
-Scott
I have a different stance. I would allow guest with 802.11n speeds and here is why I state that. Wireless is a half duplex medium. If I can get a guest frame on and off the medium 5 times faster with 802.11n, why not. Other wise, your guest clients are the slow pokes on the high way that everyone is trying to get around ...
just my 2 pennys ..
10 REPLIES 10
Hi Ryan,
Hall of Fame Community Legend
Sorry George, I'll disagree with you on this.
With 3602i, you get 4 x 4 MIMO.  This means that with channel bonding, you'll be seeing a potential 450 mbps of bandwidth.
I over looked the 3602i comment. Then YES, ... but the 4x4 wont get you 450, the 4 spatials will get you 450
Hall of Fame Master
-Scott
Beginner
So to clarify, use one guest SSID and just allow all radios?
A side question to go with it... do I need to keep the default WLAN that's mapped to the management interface that was created when I setup my controller?  I can't find any info about it...
Hall of Fame Master
Sent from my iPhone
-Scott
just my 2 pennys ..
Beginner
Thanks guys, appreciate the responses!
Ryan,
never use the managment vlan for any WLAN. Other wise clients will be sitting in the same VLAN as your managment intrerfaces to you WLCs.
As Scott pointed out. You should map your guest to a sperate VLAN that is either anchored to another WLC in the DMZ OR has ACLs blocking it from the network.
Also, make sure you apply proper QoS settings to your guest traffic so they dont take priority over your other traffic. If you give guest bronze status the NAC timers are longer for guest clients.
Beginner
Thanks George.  If I had to allow older clients on the network, have you had any experience with using Client Band Select?
Content for Community-Ad
August's Community Spotlight Awards
