07-15-2019 01:20 PM - edited 07-05-2021 10:42 AM
I suspect that some users are consuming most of the bandwidth on some of my AP(s) and causing diminished throughput for my other users. What is the best way to find these users and track their activity? Is there a way to do this from the Wi-LAN controller?
Solved! Go to Solution.
07-17-2019 08:19 AM
08-09-2019 07:50 AM
07-15-2019 01:38 PM
We use Prime to take stastics, not tried 5500 Controller directly.
Other note you can limit the bandwidth per user basis to fix the issue.
Cisco and Favourite guide from VIP member .
https://mrncciew.com/2013/05/01/per-user-rate-limit-in-wlan/
07-15-2019 01:42 PM
I read in the controller guide that the vpn traffic is not limited by the traffic shaping?
07-15-2019 10:35 PM
Hi mate,
You can use the WLCCA as well if you don't have Prime.
It will give you lots of good information there.
Here is the link to download it.
https://upload.cisco.com/cgi-bin/swc/fileexg/main.cgi?CONTYPES=wlc-conf-app-dev
Thanks.
Cheers,
Raffy
07-16-2019 05:36 AM
I will take a look at this.
Ricardo
07-17-2019 08:19 AM
08-09-2019 06:17 AM
That was helpful. Thank you.
Do you know if there is a way to reset these counters without restarting the controller?
08-09-2019 07:50 AM
