Cisco Community Designated VIP Class of 2020
1771
Beginner
5508 FUS
We recently received a couple of new 5508 WLC running 7.2.103 but the FUS is running 6.0.182. Is it possible to upgrade the FUS to 7.0.0 remotley? Looking at the FUS release notes, user intervention is no longer required, Is this possible?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: 5508 FUS
Yes as long as you use 1.7.0.0. I have done it many times:) so far so good.
-Scott
10 REPLIES 10
Hall of Fame Master
Re: 5508 FUS
-Scott
Highlighted
Beginner
5508 FUS
Thanks Scott, so this can just be run from the WLC GUI just like a normal upgrade?
Hall of Fame Master
Re: 5508 FUS
Yes that is correct. Use the GUI to upload the FUS 1.7.0.0 and then reboot. It takes around 30-35 minutes before the wlc is functional, so make sure you don't panic:) I usually do a continuous ping so I know when the wlc comes back up. .
-Scott
Beginner
5508 FUS
Great I will give this a go.
Also is the FUS only appliciable to version 7.2.103.0? Is it still required if I upgrade to 7.2.110.0?
Hall of Fame Master
Re: 5508 FUS
I would think it would still needs to be installed. You can always check by doing a show sysinfo an taking a look at the FPGA, Env and USB version.
(controller)>show sysinfo
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
This indicates that the FPGA version is 1.3 (which is less than 1.7), so the FUS upgrade must be performed.
-Scott
Beginner
5508 FUS
Just finished applying this remotley our 4 5508s running 7.2.103.0 and it worked perfectly. Thank you
Firmware Version................................. FPGA 1.7, Env 1.8, USB console
Hall of Fame Master
5508 FUS
There you go... it did take around 30 minutes or so correct?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
5508 FUS
Just fyi 7.2.103.0 has got a bug which screwed us big time in a production environment and we upgraded to 7.2.110.0
https://supportforums.cisco.com/thread/2158202
cheers
Hall of Fame Master
Re: 5508 FUS
They all have bugs:)
Depending on the feature, what bug did you hit?
-Scott
Re: 5508 FUS
it was CSCtx80961 Scott. nasty one! we upgraded and it happened the next day.
cheers
Content for Community-Ad
August's Community Spotlight Awards
