01-30-2015 12:16 PM - edited 07-05-2021 02:23 AM
I am using 3.7 code on 5760 controller with web auth and mac filtering
Policy manager state remians the above
01-30-2015 12:30 PM
why use mac filtering with webauth? jsut use webauth alone and finish the client flow (redirect, under username pass etc)
02-04-2015 03:15 PM
If the mac-address in the database, we dont want the user to enter a username and password again. We just want to goto internet.
Like employee comes everyday to office, dont need to authenticate everyday.
02-04-2015 03:21 PM
I read some forum saying the 5760 supports the Central web-auth but not the web-redirect.
using login-method "Controller initiated" doesn't work towards IOS XE (5760, 3850).
Need to use login-method "Server initiated" which means CoA. This method is used for wired switches and referenced as MAB or MAC-filtering.
But yet to receive confirmation from cisco.
04-01-2015 10:04 PM
Hi Selvas
did you get confirmation web-redirect not support in 5760.
I'm trying to configure web-redirct but unfortunately no luck.
04-20-2015 06:02 AM
Did you get a respone from Cisco on this ?
Im having an issue where the client is stuck in "WEBAUTH_PEND " on my 3850.
It all looks fine in ISE logs.
06-08-2015 01:12 AM
i got this worked with ISE. Finally all worked.
06-09-2015 06:28 AM
Yes only the WebAuth can be good to go.
06-10-2015 05:53 PM
IP http server and
IP http secure-server
commands are required to web auth.
Please let me know If the solution is helpful.
