05-20-2014 09:52 AM - edited 07-05-2021 12:52 AM
Hi ,
Is it possible to only enable 802.11g on my cisco aironet 1600 series ? I don't want N in there.
many thanks
05-20-2014 05:06 PM
If you don't want "N" then disable WMM.
If you want 802.11g only, disable data rates 1 Mbps to 11 Mbps.
06-05-2014 07:29 AM
thanks very much .
is this by either going to Network --> Network interface --> radio 802.11n 2g.hz and then disable world mode
or type no world mode under interface configuration mode?
I have done both but still insidder thinks my AP is advertising g,n so what am I missing
06-05-2014 07:44 AM
is it also possible to change the channel width to 20mhz?
06-05-2014 03:16 PM
By default, all radios are on 20 Mhz channel width.
There is NO OPTION to change the channel width of 802.11b radio to 40 Mhz.
05-20-2014 11:56 PM
Agree with Leo.
First : "802.11n" requires WPA2/AES or OPEN authentication. So if you do not use these then it will not work.
Second: Under WLAN SSID > QoS feature then disable WMM. Usually WMM is required for 802.11n support.
These are the main 2 feature required to use 802.11n rates.
If you disable one of them then you will not get 802.11n rate.
Hope it helps.
Dont forget to rate helpful posts
05-29-2014 12:40 PM
Disable WMM if you don''t want N in there.
05-30-2014 08:44 PM
I agree with the previous posts, but if you only want to turn it off on a single AP within your network then you will need to do the following:
I hope this helps.
John
