Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
870
Highlighted
Participant
9800-CL Network Configuration
Hi All,
I'm setting up a Cisco 9800-CL WLC and I want to check if there are any issues with using a single VLAN/IP for both WLC and AP management?
We currently have a management VLAN that is presented to our ESXi hosts and we dont want to setup a second VLAN/IP network for AP management (if possible). Client traffic will be locally switched at the AP via Flexconnect so we will not need to map WLANs to local VLANs on the WLC for centrally switched traffic.
At the moment my test WLC is setup as follows:
interface GigabitEthernet1
switchport trunk allowed vlan 10
switchport mode trunk
negotiation auto
no mop enabled
no mop sysid
interface Vlan10
ip address 10.1.1.1 255.255.255.0
no mop enabled
no mop sysid
wireless management interface Vlan10
Interfaces Gig2 and Gig3 are shut down. This seems to work ok and APs are registering correctly. Are there any problems with this that will cause me issues in the future?
1 ACCEPTED SOLUTION
Highlighted
Beginner
Re: 9800-CL Network Configuration
Hello willscotty2012,
I have been running a couple of 9800-CL now with the setup you have setup without any issues. The main reason for the other two ports are for Redundancy (RP port on the old WLCs) and WLC management (Management/SP port on the old WLCs) or if you need a separate interface for management instead of a trunk that shares the vlans needed.
regards,
Jonas
**Don't forget to rate helpful posts**
2 REPLIES 2
Highlighted
Beginner
regards,
Jonas
Highlighted
Participant
Hello guys,
Here we ave the exact same configuration but with a different VLAN and IP address, no way to get the WLC ping the Gateway... But when I turn interface GigabitEthernet1 to L* with no switchport, and assign the IP address to Gi1 it is working.
I am running out of idea...
Any idea ?
Thank you.
A.
Content for Community-Ad
Cisco COVID-19 Survey
