11-11-2019 10:38 PM - edited 07-05-2021 11:17 AM
Hi there,
i have half of my AP's frequently disassociate with my Cisco WLC, i found some log message in one of the access point which found those messages as in attachment.
Is it there possible a software bug? the WLC firmware is 8.8.100.0
however not all access point having this problem so it kinda of weird if the software bug cause the problem.
guys any idea?
Solved! Go to Solution.
11-11-2019 10:44 PM
11-11-2019 10:44 PM
11-12-2019 12:11 AM
Will try to to upgrade the firmware.
11-14-2019 11:01 PM
Upgraded the firmware to 8.8.125.0, so far working fine and under monitoring.
11-12-2019 08:50 AM
What ap model do you have and do you have any modules connected?
11-12-2019 06:45 PM
i have AIR-AP1832I-K-K9 & AIR-AP2802I-K-K9 all using power injector.
11-12-2019 07:24 PM
11-12-2019 07:39 PM
Hi Scott,
i found a bug which closer to my scenario.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc42741/?rfs=iqvred
06-10-2022 01:35 AM - edited 06-10-2022 09:01 AM
I also see this bug with AP 2802i and WLC in version 8.5.140.
Will the upgrade to version 8.5.182 (last possible for my CT-5508 at the end of life) not mentioned in the bug id CSCvc42741 correct this please?
Thanks in advance
Jérôme
