643
Beginner
Access point not joining the vWLC (AIR-LAP1141N-E-K9)
For my home LAB i`m using a cisco vWLC (version 8.3.143.0). and i`m try to join this access point.
But that is not join.
This is the logging of the access point:
*Apr 6 12:18:35.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.100.250:5246
*Apr 6 12:18:36.008: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface is getting down
*Apr 6 12:18:36.072: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Apr 6 12:18:36.091: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Apr 6 12:18:36.094: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Apr 6 12:18:36.134: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 6 12:18:37.090: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Apr 6 12:18:37.122: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Apr 6 12:18:37.126: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 6 12:18:38.150: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 6 12:18:39.149: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Apr 6 12:18:46.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.100.250 peer_port: 5246
*Apr 6 12:18:46.003: DTLS_CLIENT_ERROR: ../capwap/base_capwap/dtls/base_capwap_dtls_handshake.c:94 First fragment for seq 2 is missing
*Apr 6 12:18:46.487: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.100.250 peer_port: 5246
*Apr 6 12:18:46.488: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.100.250
*Apr 6 12:18:51.487: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.100.250
And it all starts over again
This is the output of en access point:
AP0022.bd1b.70bd#sho version
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 15.3(3)JD16, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 05-Jun-18 04:14 by prod_rel_team
ROM: Bootstrap program is C1140 boot loader
BOOTLDR: C1140 Boot Loader (C1140-BOOT-M) Version 12.4(18a)JA, RELEASE SOFTWARE (fc4)
AP0022.bd1b.70bd uptime is 19 minutes
System image file is "flash:/c1140-k9w8-mx.153-3.JD16/c1140-k9w8-xx.153-3.JD16"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1141N-E-K9 (PowerPC405ex) processor (revision A0) with 98294K/32768K bytes of memory.
Processor board ID FCZ1342W0Z9
PowerPC405ex CPU at 586Mhz, revision number 0x147E
Last reset from power-on
LWAPP image version 8.3.143.0
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:22:BD:1B:70:BD
Part Number : 73-11451-06
PCB Serial Number : FOC133721VB
Top Assembly Part Number : 800-31652-01
Top Assembly Serial Number : FCZ1342W0Z9
Top Revision Number : A0
Product/Model Number : AIR-LAP1141N-E-K9
Configuration register is 0xF
4 REPLIES 4
Hall of Fame Cisco Employee
Re: Access point not joining the vWLC (AIR-LAP1141N-E-K9)
Might want to move your thread to the wireless area, you're in the UC area of CSC.
java
if this helps, please rate
Highlighted
Beginner
How do I that
James Tomahawk
Hall of Fame Community Legend
Post the complete output to the following commands:
1. vWLC: sh sysinfo;
2. vWLC: sh time;
3. vWLC: sh license
Beginner
check the time have your controller WLC
Content for Community-Ad
August's Community Spotlight Awards
