04-09-2019 11:50 AM - edited 07-05-2021 10:13 AM
I am having issues adding additional AP's currently i have 15 aps no problem but trying to add 2 more and no luck , they do show under statistics ap join with ip addresses assigned but status not joined.
also found this:
Reason For Last Unsuccessful Attempt
Layer 3 discovery request not received on management VLAN
Solved! Go to Solution.
04-11-2019 04:59 AM
I figured out as it sounds very strange, i changed the port where the AP was connected not to be Trunk and i was able to join the WLC then changed it back to trunk and good to go.
thank you all
04-09-2019 12:01 PM
Check whether the WLC is reachable from the AP. Also please share the Model of AP which you are trying to join.
04-09-2019 12:04 PM
04-09-2019 12:36 PM
Model of the AP is AIR-CAP3502E-A-K9 and you mean connect console to the ap and try to ping the WLC ?
04-09-2019 12:40 PM
Yes, Try to ping the WLC from the AP. Also check whether you are getting any error message on the console. If possible post those error logs.
04-09-2019 12:11 PM
Is this new AP connected to Same Access Switch , same IP addres Range ?
how is the IP address allocated to these AP ? from DHCP ?
what is the AP working IP range, what is new AP IP range ?
04-09-2019 12:46 PM
04-09-2019 09:55 PM
This error "Layer 3 discovery request not received on management VLAN" could mean:
1. WLC is not added on DHCP option
2. Vlan may not be allowed all the way to the respective trunk links
Can you send the logs when you console to the AP.
Cheers
04-10-2019 12:02 AM
04-10-2019 07:30 AM
04-10-2019 11:11 PM
Hi mate,
Can you enable the debug on WLC.
Reload the AP once debugs are enabled.
And please post the results here.
Thanks.
WLC:
debug mac add <ap mac>
debug client <ap mac>
debug capwap events events enable
debug capwap errors enable
AP:
show log
04-11-2019 04:59 AM
thank you all
04-10-2019 11:38 PM
