Highlighted
Beginner
Activate certain SSID on certain AP in WLC
in current environment i have 3SSID , SSID_1, SSID_2 and SSID_3
most AP requires all 3 of them
certain AP in certain location such as in the lobby, i just need SSID_1
is this possible? any hint on this?
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Yes you can. It's called AP Groups. You define a group to broadcast certain SSIDs. Then you can assign APs to that group.
-Scott
4 REPLIES 4
Highlighted
Hall of Fame Master
-Scott
Highlighted
Thanks scott ! This will do the trick !
Highlighted
Hall of Fame Master
No problem and thanks for using the rating system!
-Scott
Highlighted
Hall of Fame Master
Here is a good link
https://supportforums.cisco.com/docs/DOC-19033
-Scott
