Ad- hoc Net.
mohamedamir
i don`t know routing protocol for wireless Ad-hoc Network .. i need a help in this topic ,,, Thnx "
Damon Garner
Mohamed,
ad-hoc networks are between end clients only, there is no routing.
The network is ad hoc because it does not rely on a preexisting infrastructure, such as routers in wired networks or access points in managed (infrastructure) wireless networks. Instead, each node participates in routing by forwarding data for other nodes, and so the determination of which nodes forward data is made dynamically based on the network connectivity. In addition to the classic routing, ad hoc networks can use flooding for forwarding the data.
Damon
Rate all answers please.
thnx about you answer ,, now there was no routing in AD-hoc net ...when i wan`t to make 10 sensors in 10 cars and want to connect the sensors with others ,,how can i make it ( Hint : this sensor for knowing driver that there was ana accidant on the road ) ,,, thnx Damon
Just to add... These devices have to be in range of one another.
http://compnetworking.about.com/cs/wirelessfaqs/f/adhocwireless.htm
-Scott
