06-02-2020 08:57 AM - edited 07-05-2021 12:07 PM
Having a hard time finding the correct documentation/answer to add another VLAN to an Aironet Wireless bridge. I just inherited this setup & still coming up to speed.
Have 3 existing Cisco AIRBR 1410 & I need to add another VLAN to the bridge group.
They are out of support & end of life. Hopefully they can be replaced later this year, but need to live with them for now.
Below is a current config of one of the VLANs (VLAN 103). Currently 6 are being trunked across the bridge
dot11 vlan-name v103 vlan 103
interface Dot11Radio0.103
encapsulation dot1Q 103
no ip route-cache
bridge-group 103
bridge-group 103 spanning-disabled
interface FastEthernet0.103
no ip route-cache
bridge-group 103
I assume if I want to add a new VLAN20... I would just copy the above config for the new VLAN?
dot11 vlan-name v20 vlan 20
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 spanning-disabled
interface FastEthernet0.20
no ip route-cache
bridge-group 20
Thanks & I appreciate any help.
Cheers!
Solved! Go to Solution.
06-02-2020 09:13 AM
this is a good document for multiple VLANs on a WGB or bridge AP
06-02-2020 01:56 PM
Yes, that config will achieve what you want.
Make sure clan 20 defined on your switches
Rasika
06-02-2020 09:13 AM
06-02-2020 01:56 PM
Rasika
06-03-2020 02:16 PM
Thanks & I appreciate the help.
Cheers!
