156
Highlighted
Beginner
Adding access point to WLC 2504
I have 7 access points running on WLC 2504 and trying to add another one for a total of 8 APs
Sysinfo shows I am allowed up to 75 access points,
license is showing I have 7 AP in use of 7 available but have another license for 5 not in use.
What is the best way to proceed here? new license?
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.166.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name......................................
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address.......................................
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 99 days 10 hrs 9 mins 52 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country...............................
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +27 C
External Temperature............................. +31 C
Fan Status....................................... 3800 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 6
Number of Active Clients......................... 162
Burned-in MAC Address............................
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
5 REPLIES 5
Beginner
Re: Adding access point to WLC 2504
and the license in use
75 is the maximum count support by 2500 model controller.
Currently you have 7 no. of license in your controller.
Issue the command show udi on the cli of WLC and share the Product ID of it.
May be this WLC procured with 5 AP license and later 2 more adder license where installed on it.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Beginner
(Cisco Controller) >show udi
NAME: "Chassis"    , DESCR: "Cisco 2500 Series Wireless LAN Controller"
PID: AIR-CT2504-K9,  VID: V06,  SN: PSZ20101HQ5
I was hoping to be able to use the additional 5 licences or add one more to the existing 7
Otherwise, what would be my options?
Seems at the initial stage controller was having the 5 AP license installed and then additional 2 license (So its showing 5 + 2 = 7)were installed on that. Currently the 7 license is in active.
If you want to add more than 7 APs, You have to purchase license and have to install in on the WLC.
VIP Engager
As this product is EOS, I think you can't anymore buy licenses for it, but better check that with your Cisco Reseller.
You require an "Adder License" for the amount of additional APs you want.
Don't forget to reboot the WLC after adding a new license.
