07-24-2019 12:21 PM - edited 07-05-2021 10:44 AM
I have a 5508 WLC running software version 8.3.122.0 and some brand new Aironet 1815i Access Points. Just plugging the APs they should find the WLC, but all the do is flash green. How can I get them to see the WLC? or get them on my network?
Solved! Go to Solution.
07-25-2019 09:37 AM - edited 07-25-2019 09:40 AM
Apparently I figured it out. My controller now sees the AP. I had to console in and setup the AP, then go into the CLI and use...
ap-type capwap
that got it going.
07-24-2019 01:26 PM
you will need to upgrade you WLC to 8.5 code before the AP can join.
I hope this helps
David
07-24-2019 01:35 PM
Ok question then, will my old 1142 aps work. I had updated at one time and those couldn't be seen. I need to run both the 1142 and 1815 simultaneously, working on a budget.
07-24-2019 02:18 PM
Hi @tombstone1
Not really sure, but at least in 1852 the led blink in green when they´re joined to WLC. The LEDs behavior are different from your 1142. Not sure what you need to upgrade as @d.friday said, I check out the wireless compatibility matrix and it says you can have both 1815i and 1142.
You can check the matrix here.
If your have access to your WLC you can do a "show ap summary"
not sure if I understand really good, because I'm not a english native speaker. But well, the last versión that support your 1142 is 8.3.150.0
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
07-24-2019 02:25 PM - edited 07-24-2019 02:33 PM
I saw the Matrix, and that is why I got the 1815i's. I can't download a software update. It should be compatible with both, but the 1815i isn't connecting. If someone wants to tell me how to setup each AP to connect the WLC I will do it manually.
07-24-2019 03:33 PM
The APs have CAPWAP Image right?
can you shared the output of your "show version" command
About the manual configuration you ca try:
capwap ap ip address X.X.X.X 255.255.255.X
capwap ap ip default-gateway X.X.X.X
capwap ap controller ip address X.X.X.X
07-24-2019 04:16 PM
I don't know. I tried earlier to do those but the commands didn't work. All the aps ask for me to quite autoinstall, and I don't know what to fill in for them exactly. The questions are rather vague in my opinion. as I tried to do it manually earlier and what I thought I was filling out I wasn't.
07-24-2019 04:46 PM
Hi @tombstone1
I think the AP can have Mobility express image, can you share the output of "show version" command?
ap-type capwap
that got it going.
07-24-2019 09:52 PM
Both type of AP should work with this((8.3.x) version. But still i will recommand to use 8.3.150.0(Stable one).
Paste the output of these commands:
sh sysinfo from WLC
sh version from AP
and the complete bootup process from AP Console.
Dont foirget to rate helpful posts
07-25-2019 09:08 AM
Sysinfo for WLC
(Cisco Controller) >show sysinfo Manufacturer's Name.............................. Cisco Systems Inc. Product Name..................................... Cisco Controller Product Version.................................. 8.3.122.0 Bootloader Version............................... 1.0.1 Field Recovery Image Version..................... 6.0.182.0 Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27 OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014 Build Type....................................... DATA + WPS System Name...................................... WLC-Tombstone System Location.................................. System Contact................................... System ObjectID.................................. 1.3.6.1.4.1.9.1.1069 Redundancy Mode.................................. Disabled IP Address....................................... 10.0.4.50 IPv6 Address..................................... :: Last Reset....................................... Software reset System Up Time................................... 0 days 16 hrs 7 mins 27 secs System Timezone Location......................... (GMT -7:00) Mountain Time (US and Canada) System Stats Realtime Interval................... 5 --More-- or (q)uit System Stats Normal Interval..................... 180 Configured Country............................... US - United States Operating Environment............................ Commercial (0 to 40 C) Internal Temp Alarm Limits....................... 0 to 65 C Internal Temperature............................. +36 C External Temperature............................. +22 C Fan Status....................................... OK State of 802.11b Network......................... Enabled State of 802.11a Network......................... Enabled Number of WLANs.................................. 5 Number of Active Clients......................... 46 OUI Classification Failure Count................. 0 Burned-in MAC Address............................ E0:2F:6D:5D:35:80 Power Supply 1................................... Present, OK Power Supply 2................................... Absent Maximum number of APs supported.................. 500 System Nas-Id.................................... WLC MIC Certificate Types........................ SHA1
SH Version for AP
Manufacturer's Name.............................. Cisco Systems Inc. Product Name..................................... Cisco Controller Build Info....................................... Engineering Special Product Version.................................. 8.5.140.0 System Name...................................... Cisco_6e:53:e0 System Location.................................. System Contact................................... System ObjectID.................................. 1.3.6.1.4.1.9.1.2489 IP Address....................................... 10.0.4.50 Last Reset....................................... 1: reload command System Up Time................................... 0 days 0 hrs 3 mins 54 secs System Timezone Location......................... (GMT -7:00) Mountain Time (US and Canada) System Stats Realtime Interval................... 5 System Stats Normal Interval..................... 180 Configured Country............................... US - United States State of 802.11b Network......................... Enabled State of 802.11a Network......................... Enabled --More-- or (q)uit Number of WLANs.................................. 1 Number of Active Clients......................... 0 OUI Classification Failure Count................. 0 Memory Current Usage............................. 45 Memory Average Usage............................. 46 CPU Current Usage................................ 6 CPU Average Usage................................ 7 Flash Type....................................... Compact Flash Card Flash Size....................................... 1073741824 Burned-in MAC Address............................ C4:F7:D5:6E:53:E0 Maximum number of APs supported.................. 50 System Nas-Id.................................... WLC MIC Certificate Types........................ SHA1/SHA2
AP Startup
Writing reload timestamp (Sun Jun 16 19:31:16 UTC 2019) to disk [06/16/2019 19:31:18.8499] UBIFS: un-mount UBI device 0, volume 3 [06/16/2019 19:31:18.9099] UBIFS: background thread "ubifs_bgt0_3" stops [06/16/2019 19:31:19.6999] reboot: Restart Board type: AP1815I smem ram ptable found: ver: 1 len: 3 U-Boot 2012.07 (btldr release 36) (Oct 13 2017 - 10:35:07) This product contains some software licensed under the "GNU General Public License, version 2" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU General Public License, version 2", available here: http://www.gnu.org/licenses/old-licenses/gpl-2.0.html DRAM: 1022 MiB Nand: Detected ONFI Winbond NAND 256MiB 3,3V 8-bit NAND ECC=1 ECC_THRESHOLD(NAND ECC-1)=0 SF: Detected MX25L3205D with page size 4 KiB, total 4 MiB MFG data loaded Scanning shenv data blocks Total valid parts=4 Active shenv part[0:1], write_counter=10 machid: 8010001 Net: MAC0 addr:c4:f7:d5:6e:53:f0 AR8033 PHY 0 PHY ID1: 0x4d PHY ID2: 0xd072 ipq40xx_ess_sw_init done Auto boot mode, use bootipq directly Hit ESC key to stop autoboot: 0 Specified BOOT: part2 Booting from part2 Read 1024 bytes from volume part2 to 88000000 Read 42868375 bytes from volume part2 to 88000000 Signature returns 0 Image signing verification success, continue to run... bootm 0x88000400 ## Booting kernel from Legacy Image at 88000400 ... ## Loading init Ramdisk from multi component Legacy Image at 88000400 ... ## Flattened Device Tree from multi component Image at 88000400 Booting using the fdt at 0x8a8d8a50 Loading Ramdisk to 9d8f1000, end 9fffffe0 ... OK Loading Device Tree to 9d8e5000, end 9d8f0c46 ... OK no such device nand0 Using machid 0x8010001 from environment Starting image ... [01/01/1970 00:00:41.5099] Linux version 3.14.43 (vipendya@wnbu-bld-lnx9) (gcc v ersion 4.7.1 (OpenWrt GCC 4.7.1 r48430) ) #1 SMP PREEMPT Sun Nov 25 05:39:12 PST 2018 [01/01/1970 00:00:41.6699] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), c r=10c5387d [01/01/1970 00:00:41.7599] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasin g instruction cache [01/01/1970 00:00:41.8699] Machine model: Cisco 11ac Wave2 Wifi Access Point [01/01/1970 00:00:41.9499] Memory policy: Data cache writealloc [01/01/1970 00:00:42.0199] Kernel command line: console=ttyMSM0,9600n8 ubi.mtd=0 root=/dev/ram activepart=part2 activeboot=0 wdgtriggered=0 board_sku=1 clk_igno re_unused [01/01/1970 00:00:42.1999] CPU1: Booted secondary processor [01/01/1970 00:00:42.2599] CPU2: Booted secondary processor [01/01/1970 00:00:42.3199] CPU3: Booted secondary processor [01/01/1970 00:00:42.3899] buginf tty flushing thread started, ttyport=b3651400 [*01/01/1970 00:00:45.7699] buginf() enabled. [*01/01/1970 00:00:45.7999] Made it into bootsh: Nov 25 2018 05:46:24 [*01/01/1970 00:00:45.7999] bootsh build T-b1c4d316cf409bad6ec9cbf2958c6014776e9 5f2-gb1c4d316-vipendya Welcome to Cisco. Usage of this device is governed by Cisco's End User License Agreement, available at: http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html. Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. Cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. This product contains some software licensed under the "GNU General Public License, version 2" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU General Public License, version 2", available here: http://www.gnu.org/licenses/old-licenses/gpl-2.0.html This product contains some software licensed under the "GNU Library General Public License, version 2" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU Library General Public License, version 2", available here: http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html This product contains some software licensed under the "GNU Lesser General Public License, version 2.1" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser General Public License, version 2.1", available here: http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html This product contains some software licensed under the "GNU General Public License, version 3" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU General Public License, Version 3", available here: http://www.gnu.org/licenses/gpl.html. This product contains some software licensed under the "GNU Affero General Public License, version 3" provided with ABSOLUTELY NO WARRANTY under the terms of "GNU Affero General Public License, version 3", available here: http://www.gnu.org/licenses/agpl-3.0.html. error: open /dev/board-config error: open /dev/board-config error: open /dev/board-config error: open /dev/board-config init started: BusyBox v1.23.2 (2018-11-25 05:20:04 PST) [*01/01/1970 00:00:49.3399] GCM-128 POST passed [*01/01/1970 00:00:49.3399] GCM-256 POST passed [*01/01/1970 00:00:49.4799] === 5G radio domain is 41, COPY 5G BDF files from non_ETSI_BDF folder === [*01/01/1970 00:00:49.5299] 1 [*01/01/1970 00:00:49.7199] Active version: 8.5.140.0 [*01/01/1970 00:00:49.7199] Backup version: 0.0.0.0 [*01/01/1970 00:00:50.1299] [*01/01/1970 00:00:50.1299] led pattern module start [*01/01/1970 00:00:50.1699] Loading caldata from mtd2 Jan 1 00:00:50 FIPS[2899]: *** shell: FIPS Mode = disabled *** [*01/01/1970 00:00:50.5599] ess-switch DT exist! [*01/01/1970 00:00:50.5599] switchreg_base_addr: 0xc000000 [*01/01/1970 00:00:50.5599] switchreg_size: 0x80000 [*01/01/1970 00:00:50.5599] switch_access_mode: local bus [*01/01/1970 00:00:50.5599] wan bmp:0x20 [*01/01/1970 00:00:50.5599] ess-psgmii DT exist! [*01/01/1970 00:00:50.5599] mac mode=3 [*01/01/1970 00:00:50.5599] current mac mode = 3 [*01/01/1970 00:00:50.5599] current dts led_source_num is 5 [*01/01/1970 00:00:50.5599] mdio DT exist! [*01/01/1970 00:00:50.5599] ssdk_plat_init start [*01/01/1970 00:00:50.5599] enable ess clk User Access Verification Username: [*01/01/1970 00:00:50.6699] reset ok in probe! [*01/01/1970 00:00:50.6699] PHY ID is 0x4dd072 [*01/01/1970 00:00:50.7299] Dakota Chip version 0x1401 [*01/01/1970 00:00:50.7299] [*01/01/1970 00:00:50.7299] QCA Switch config done. [*01/01/1970 00:00:50.7399] gcc map success! [*01/01/1970 00:00:50.7899] qca-ssdk module init succeeded! [*01/01/1970 00:00:50.7899] [*01/01/1970 00:00:50.7899] QCA Switch config done. [*01/01/1970 00:00:50.9899] crypto worker thread started [*01/01/1970 00:00:50.9899] crypto worker thread started [*01/01/1970 00:00:51.0499] pid 3172's current affinity mask: f [*01/01/1970 00:00:51.0499] pid 3172's new affinity mask: e [*01/01/1970 00:00:51.0499] pid 3171's current affinity mask: f [*01/01/1970 00:00:51.0499] pid 3171's new affinity mask: e [*01/01/1970 00:00:51.2799] Current value of FACTORY_RESET=0 [*06/15/2019 23:59:59.0099] Last reload time: Jun 16 19:31:16 2019 [*06/16/2019 19:31:16.0000] Setting system time Sun Jun 16 19:31:16 UTC 2019 [*06/16/2019 19:31:16.0799] device wired0 entered promiscuous mode [*06/16/2019 19:31:16.5699] stile module dp init successfully [*06/16/2019 19:31:16.5699] NBAR Label:BLD_V155_3_S_XE316_THROTTLE_LATEST_201804 04_162221 NBAR VERSION:module build date: Nov 25 2018 at 05:43:59 [*06/16/2019 19:31:16.8999] pid 3303's current affinity mask: f [*06/16/2019 19:31:16.8999] pid 3303's new affinity mask: e [*06/16/2019 19:31:16.9099] pid 3302's current affinity mask: f [*06/16/2019 19:31:16.9099] pid 3302's new affinity mask: e [*06/16/2019 19:31:16.9099] pid 3301's current affinity mask: f [*06/16/2019 19:31:16.9099] pid 3301's new affinity mask: e [*06/16/2019 19:31:17.5999] [*06/16/2019 19:31:17.6099] boot 4 build T-b1c4d316cf409bad6ec9cbf2958c6014776e9 5f2-gb1c4d316-vipendya board mallorca mac C4:F7:D5:6E:53:F0 [*06/16/2019 19:31:17.6199] Module: mbedtls .text=0x7f000000 data=0x7f00 75e0 bss=0x7f007840 [*06/16/2019 19:31:17.6199] Module: aptrace .text=0x7f00c000 data=0x7f01 7f88 bss=0x7f018470 [*06/16/2019 19:31:17.6199] Module: led_module .text=0x7f020000 data=0x7 f020594 bss=0x7f020c04 [*06/16/2019 19:31:17.6199] Module: qca_ssdk .text=0x7f024000 data=0x7f0 ba100 bss=0x7f0bfba4 [*06/16/2019 19:31:17.6199] Module: essedma .text=0x7f111000 data=0x7f11 7960 bss=0x7f117df4 [*06/16/2019 19:31:17.6199] Module: crypto_netdev .text=0x7f11f000 data= 0x7f121e7c bss=0x7f1220e0 [*06/16/2019 19:31:17.6199] Module: proclikefs .text=0x7f12b000 data= bss=0x7f12bb80 [*06/16/2019 19:31:17.6199] Module: stile_lm_ft .text= data= bss= [*06/16/2019 19:31:17.6199] Module: stile_lm_dp .text= data= bss= [*06/16/2019 19:31:17.6199] Module: ipv6 .text=0x7fc72000 data=0x7fcab00 0 bss=0x7fcac600 [*06/16/2019 19:31:17.6199] Module: llc .text=0x7fcd3000 data=0x7fcd3844 bss=0x7fcd39d0 [*06/16/2019 19:31:17.6199] Module: stp .text=0x7fcd8000 data=0x7fcd8280 bss=0x7fcd842c [*06/16/2019 19:31:17.6199] Module: act2_driver .text=0x7fcdc000 data=0x 7fcdc76c bss=0x7fcdc9f0 [*06/16/2019 19:31:17.6199] Module: bridge .text=0x7fce0000 data=0x7fce8 a98 bss=0x7fce8ed8 [*06/16/2019 19:31:17.6199] Module: p8022 .text=0x7fcf5000 data= bss= [*06/16/2019 19:31:17.6199] Module: psnap .text=0x7fcf9000 data=0x7fcf93 48 bss=0x7fcf94b8 [*06/16/2019 19:31:17.6199] Module: reed_solomon .text=0x7fcfd000 data=0 x7fcfe3fc bss= [*06/16/2019 19:31:18.2799] Last reload reason : 1: reload command [*06/16/2019 19:31:20.6199] __mm_init_module [*06/16/2019 19:31:20.6999] ol_ath_ahb_probe [*06/16/2019 19:31:20.6999] ol_ath_ahb_probe: io resource start: 0xa000000, mem= 0xc2800000 [*06/16/2019 19:31:20.6999] [*06/16/2019 19:31:20.6999] __ol_ath_attach() Allocated scn 9e0c04c0 [*06/16/2019 19:31:20.6999] ol_ath_ahb_configure: MSI addr: 0b006040, MSI base: 00000040 [*06/16/2019 19:31:20.7099] [*06/16/2019 19:31:20.7099] ol_ath_ahb_configure : num_desired MSI set to 0 [*06/16/2019 19:31:20.7099] [*06/16/2019 19:31:20.7099] Using Legacy Interrupt [*06/16/2019 19:31:20.7099] [*06/16/2019 19:31:20.7099] Waiting for target init [*06/16/2019 19:31:20.7099] [*06/16/2019 19:31:20.7099] Done waiting [*06/16/2019 19:31:20.7099] ol_ath_attach interface_id 0 [*06/16/2019 19:31:20.7099] Chip id: 0xb, chip version: 0x1000000 [*06/16/2019 19:31:20.7099] [*06/16/2019 19:31:20.7099] Target Version is 1000000 [*06/16/2019 19:31:20.7099] [*06/16/2019 19:31:20.7099] Flash Download Address c0000 [*06/16/2019 19:31:20.7099] ol_transfer_bin_file: flash data file defined [*06/16/2019 19:31:20.7099] ol_transfer_bin_file[3918] Get Caldata for wifi0. [*06/16/2019 19:31:20.7099] __adf_os_fs_read[42], Open File /tmp/wifi0.caldata S UCCESS!! [*06/16/2019 19:31:20.7099] file system magic:16914836 [*06/16/2019 19:31:20.7099] super blocksize:4096 [*06/16/2019 19:31:20.7099] inode 6164 [*06/16/2019 19:31:20.7099] file size:12064 [*06/16/2019 19:31:20.7099] qc98xx_verify_checksum: flash checksum passed: 0xa97 1 [*06/16/2019 19:31:20.7099] ol_transfer_bin_file 3979: Download Flash data len 1 2064 [*06/16/2019 19:31:20.7399] [*06/16/2019 19:31:20.7399] Board data initialized [*06/16/2019 19:31:20.7399] Firmware loaded from user helper succesfully [*06/16/2019 19:31:20.7599] ol_ath_download_firmware :First OTP download and Exe cute is good address:0x5800 return param 4660 [*06/16/2019 19:31:20.7599] ol_ath_download_firmware:##Board Id 22 , CHIP Id 0 [*06/16/2019 19:31:20.7599] [*06/16/2019 19:31:20.7599] wifi0: Selecting board data file name boardData_Mal lorca_EAP_2G_neg_pwr.bin [*06/16/2019 19:31:20.7599] ol_transfer_bin_file: Board Data File download to ad dress=0xc0000 file name=IPQ4019/hw.1/boardData_Mallorca_EAP_2G_neg_pwr.bin [*06/16/2019 19:31:20.7599] Firmware loaded from user helper succesfully [*06/16/2019 19:31:20.7799] Firmware loaded from user helper succesfully [*06/16/2019 19:31:20.7899] [*06/16/2019 19:31:20.7899] [Flash] : Ignore Module param [*06/16/2019 19:31:20.7899] ol_ath_download_firmware : Second OTP download and E xecute is good, param=0x0 [*06/16/2019 19:31:20.7999] Firmware loaded from user helper succesfully [*06/16/2019 19:31:20.7999] Firmware loaded from user helper succesfully [*06/16/2019 19:31:20.8099] ol_transfer_bin_file: Downloading firmware file: IPQ 4019/hw.1/athwlan.bin [*06/16/2019 19:31:20.8099] Firmware loaded from user helper succesfully [*06/16/2019 19:31:22.0299] HTC Rx: insufficient length, got:4 expected =8 [*06/16/2019 19:31:22.0299] Startup Mode-0 set [*06/16/2019 19:31:22.0299] HTC Service:0x0300 ep:1 TX flow control disabled [*06/16/2019 19:31:22.0399] HTC Service:0x0100 ep:2 TX flow control disabled [*06/16/2019 19:31:22.0399] Firmware_Build_Number:70 [*06/16/2019 19:31:22.0399] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht _cap_info:0x339959b2 vht_supp_mcs:0x0000fffa [*06/16/2019 19:31:22.0399] [*06/16/2019 19:31:22.0399] RES CFG Support wmi_service_bitmap 9778 [*06/16/2019 19:31:22.0399] [*06/16/2019 19:31:22.0399] Sending Ext resource cfg: HOST PLATFORM as 0 and fw _feature_bitmap as 50 to TGT [*06/16/2019 19:31:22.0399] ol_ath_service_ready_event: sw_cal_support_check_fla g: 1 [*06/16/2019 19:31:22.0399] ol_ath_service_ready_event[4238] WAPI MBSSID 0 [*06/16/2019 19:31:22.0799] wmi_ready_event_rx: WMI UNIFIED READY event [*06/16/2019 19:31:22.0799] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FR AG_DESC_BANK_CFG sent to FW for radio ID = 0 [*06/16/2019 19:31:22.0899] ACS not enabled [*06/16/2019 19:31:22.0899] ol_ath_thermal_mitigation_attach: -- [*06/16/2019 19:31:22.0899] ol_ath_ahb_probe [*06/16/2019 19:31:22.0899] ol_ath_ahb_probe: io resource start: 0xa800000, mem= 0xc3000000 [*06/16/2019 19:31:22.0899] [*06/16/2019 19:31:22.0899] __ol_ath_attach() Allocated scn 9ecc04c0 [*06/16/2019 19:31:22.0899] ol_ath_ahb_configure: MSI addr: 0b006040, MSI base: 00000050 [*06/16/2019 19:31:22.0999] [*06/16/2019 19:31:22.0999] ol_ath_ahb_configure : num_desired MSI set to 0 [*06/16/2019 19:31:22.0999] [*06/16/2019 19:31:22.0999] Using Legacy Interrupt [*06/16/2019 19:31:22.0999] [*06/16/2019 19:31:22.0999] Waiting for target init [*06/16/2019 19:31:22.0999] [*06/16/2019 19:31:22.0999] Done waiting [*06/16/2019 19:31:22.1099] ol_ath_attach interface_id 1 [*06/16/2019 19:31:22.1099] Chip id: 0xb, chip version: 0x1000000 [*06/16/2019 19:31:22.1099] [*06/16/2019 19:31:22.1099] Target Version is 1000000 [*06/16/2019 19:31:22.1099] [*06/16/2019 19:31:22.1099] Flash Download Address c0000 [*06/16/2019 19:31:22.1099] ol_transfer_bin_file: flash data file defined [*06/16/2019 19:31:22.1099] ol_transfer_bin_file[3918] Get Caldata for wifi1. [*06/16/2019 19:31:22.1099] __adf_os_fs_read[42], Open File /tmp/wifi1.caldata S UCCESS!! [*06/16/2019 19:31:22.1099] file system magic:16914836 [*06/16/2019 19:31:22.1099] super blocksize:4096 [*06/16/2019 19:31:22.1099] inode 6165 [*06/16/2019 19:31:22.1099] file size:12064 [*06/16/2019 19:31:22.1099] qc98xx_verify_checksum: flash checksum passed: 0x544 3 [*06/16/2019 19:31:22.1099] ol_transfer_bin_file 3979: Download Flash data len 1 2064 [*06/16/2019 19:31:22.1299] [*06/16/2019 19:31:22.1299] Board data initialized [*06/16/2019 19:31:22.1299] Firmware loaded from user helper succesfully [*06/16/2019 19:31:22.1499] ol_ath_download_firmware :First OTP download and Exe cute is good address:0x5c00 return param 4660 [*06/16/2019 19:31:22.1499] ol_ath_download_firmware:##Board Id 23 , CHIP Id 0 [*06/16/2019 19:31:22.1599] [*06/16/2019 19:31:22.1599] wifi1: Selecting board data file name boardData_Mal lorca_EAP_5G_neg_pwr.bin [*06/16/2019 19:31:22.1599] ol_transfer_bin_file: Board Data File download to ad dress=0xc0000 file name=IPQ4019/hw.1/boardData_Mallorca_EAP_5G_neg_pwr.bin [*06/16/2019 19:31:22.1599] Firmware loaded from user helper succesfully [*06/16/2019 19:31:22.1799] Firmware loaded from user helper succesfully [*06/16/2019 19:31:22.1899] [*06/16/2019 19:31:22.1899] [Flash] : Ignore Module param [*06/16/2019 19:31:22.1899] ol_ath_download_firmware : Second OTP download and E xecute is good, param=0x0 [*06/16/2019 19:31:22.1899] Firmware loaded from user helper succesfully [*06/16/2019 19:31:22.1899] Firmware loaded from user helper succesfully [*06/16/2019 19:31:22.1999] ol_transfer_bin_file: Downloading firmware file: IPQ 4019/hw.1/athwlan.bin [*06/16/2019 19:31:22.1999] Firmware loaded from user helper succesfully [*06/16/2019 19:31:23.0299] FWLOG: [100924] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x 1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:23.0299] FWLOG: [100924] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0 x1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:23.0299] FWLOG: [100924] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0 x1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:23.0299] FWLOG: [100924] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0 x1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:23.4299] HTC Rx: insufficient length, got:4 expected =8 [*06/16/2019 19:31:23.4299] Startup Mode-0 set [*06/16/2019 19:31:23.4299] HTC Service:0x0300 ep:1 TX flow control disabled [*06/16/2019 19:31:23.4399] HTC Service:0x0100 ep:2 TX flow control disabled [*06/16/2019 19:31:23.4399] Firmware_Build_Number:70 [*06/16/2019 19:31:23.4399] num_rf_chain:0x00000002 ht_cap_info:0x0000085b vht _cap_info:0x339959b2 vht_supp_mcs:0x0000fffa [*06/16/2019 19:31:23.4399] [*06/16/2019 19:31:23.4399] RES CFG Support wmi_service_bitmap 9778 [*06/16/2019 19:31:23.4399] [*06/16/2019 19:31:23.4399] Sending Ext resource cfg: HOST PLATFORM as 0 and fw _feature_bitmap as 50 to TGT [*06/16/2019 19:31:23.4399] ol_ath_service_ready_event: sw_cal_support_check_fla g: 1 [*06/16/2019 19:31:23.4399] ol_ath_service_ready_event[4238] WAPI MBSSID 0 [*06/16/2019 19:31:23.4799] wmi_ready_event_rx: WMI UNIFIED READY event [*06/16/2019 19:31:23.4799] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FR AG_DESC_BANK_CFG sent to FW for radio ID = 1 [*06/16/2019 19:31:23.4799] acfg_attach: Offload using existing sock bd2a4000 [*06/16/2019 19:31:23.4899] ACS not enabled [*06/16/2019 19:31:23.4899] ol_ath_thermal_mitigation_attach: -- [*06/16/2019 19:31:23.5599] pktlog_init: Initializing Pktlog for AR900B, pktlog _hdr_size = 16 [*06/16/2019 19:31:23.5599] pktlog_init: Initializing Pktlog for AR900B, pktlog _hdr_size = 16 [*06/16/2019 19:31:24.4299] FWLOG: [102357] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0x 1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:24.4299] FWLOG: [102357] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0 x1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:24.4299] FWLOG: [102357] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0 x1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:24.4299] FWLOG: [102357] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0 x1e, 0x94c, 0x94c, 0x0 ) [*06/16/2019 19:31:24.4299] FWLOG: [102367] UNKNOWN 22:55 ( 0x3a, 0x10, 0x0, 0x1 0, 0x0 ) [*06/16/2019 19:31:24.6399] pid 3645's current affinity mask: f [*06/16/2019 19:31:24.6399] pid 3645's new affinity mask: e [*06/16/2019 19:31:26.4799] [*06/16/2019 19:31:26.4799] Click sched monitor: schedulers = 3 [*06/16/2019 19:31:27.9999] click-config/io-real.click:131: While configuring 't odev_wired0 :: ToDevice': [*06/16/2019 19:31:27.9999] warning: device 'wired0' is down [*06/16/2019 19:31:28.0599] click-config/io-real.click:131: While configuring 'f romdev_wired0 :: FromDevice': [*06/16/2019 19:31:28.0599] warning: device 'wired0' is down [*06/16/2019 19:31:28.9699] click-config/io-real.click:131: While initializing ' tohost_wired0 :: ToHost': [*06/16/2019 19:31:28.9699] warning: device 'wired0' is down [*06/16/2019 19:31:29.4799] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgv alid[0] 00000000 cfgvalid[1] 00000000 [*06/16/2019 19:31:[06/16/2019 19:31:31.5899] ess_edma c080000.edma: wired0: GMA C Link is up with phy_speed=1000 29.4799] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cf gvalid[1] 00000000 [*06/16/2019 19:31:31.2599] chatter: tohost_srcr6 :: ToHost: device 'srcr6' went down [*06/16/2019 19:31:31.2999] chatter: tohost_srcr6 :: ToHost: device 'srcr6' came up [*06/16/2019 19:31:31.2999] ip6_port srcr6, ip6local fe80::c6f7:d5ff:fe6e:53f0, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 3(slaa c) [*06/16/2019 19:31:31.6999] IPv6: ADDRCONF(NETDEV_CHANGE): wired0: link becomes ready [*06/16/2019 19:31:40.6999] Loading sha2... [*06/16/2019 19:31:40.6999] Dumpping sha1... [*06/16/2019 19:31:42.4599] Loading MIC cert and key [*06/16/2019 19:31:42.4599] Dumpping sha2... [*06/16/2019 19:31:44.2099] Loading MIC cert and key [*06/16/2019 19:31:45.1299] Generating key, this may take a while... [*06/16/2019 19:31:55.6199] Public key portion is: [*06/16/2019 19:31:55.6199] ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDLVk3clDbSDTWr ORMW5ZdhCv/SKbgwc4TTNt34aLKr0Au/xN0258R2MZmw9mOaTylKPArW9nYR75ooRkUItNH6H5TrWX05 JU+x8YJa/Hy5bKSBNw7L6LwCe1AmErQQG/yV4bLqpeMQqK9GRU6OtjKpdIHlhgeI23sG0s3eCbrVhzCS oYgnOQC2D58jlcM8jHwjRXeE10soaBh9nb3oCKebeEc/4TBuxpH5PK0NxnsIS18Rky/K1ye+ACvl+6h5 JiuCJ/+Skh9dUmyKkOmcqkXAmA+xJP6/bMFMyEio+Vv7LMJ0sdvmVfiY9lYGVoAvv4kp/gLSn/2J/VYF MpSzNZ47 root@mC4F7D56E53F0 [*06/16/2019 19:31:55.6199] Fingerprint: sha1!! 42:6b:7e:37:02:ec:6c:17:a9:c0:a6 :85:70:80:ed:3e:f3:26:8b:2e [*06/16/2019 19:31:56.5399] pid 5469's current affinity mask: f [*06/16/2019 19:31:56.5399] pid 5469's new affinity mask: e [*06/16/2019 19:31:56.5599] setting interrupt 200 affinity to 1 [*06/16/2019 19:31:56.5799] setting interrupt 201 affinity to 1 [*06/16/2019 19:31:57.7099] Password for user changed [*06/16/2019 19:31:57.8199] gzip -dc /etc/wcp.usermodule.template.gz | sed -e ' s/__TX_POWER_2G_FILE__/\/radio_fw\/MI2.csv/g' -e 's/__TX_POWER_5G_FILE__/\/radio _fw\/MI5.csv/g' -e 's/__EVM_POWER_2G_FILE__/\/radio_fw\/EVM_2.csv/g' -e 's/__EVM _POWER_5G_FILE__/\/radio_fw\/EVM_5.csv/g' -e 's/__DOMAIN_2G__/0/g' -e 's/__DOMAI N_5G__/41/g' -e 's/__PWR_TABLE_49G__/0/g' -e 's/__PRODUCT_ID__/AIR-AP1815I-B-K9/ g' -e 's/__AP_TYPE__/66/g' -e 's/__WIRELESS_MAC__/C4:F7:D5:9E:DE:C0/g' -e 's/__W IRED_MAC__/C4:F7:D5:6E:53:F0/g' -e 's/__WIRED1_MAC__/C4:F7:D5:6E:53:F0/g' | DMAL LOC_OPTIONS=debug=0x400003,inter=1000,log=/tmp/wcp.dmalloc.log,limit=40000000 wc pd & [*06/16/2019 19:32:00.6299] CRIT-MeshControl: [*06/16/2019 19:32:00.6299] Mesh Control: skipped adding wired1 backhaul [*06/16/2019 19:32:00.6399] DOT11_DRV[0]: Init Radio0 [*06/16/2019 19:32:00.6699] DOT11_DRV[0]: Stop Radio0 [*06/16/2019 19:32:00.6799] DOT11_DRV[0]: set_channel Channel set to 6 [*06/16/2019 19:32:00.6899] DOT11_DRV[1]: Init Radio1 [*06/16/2019 19:32:00.7299] DOT11_DRV[1]: Stop Radio1 [*06/16/2019 19:32:00.7399] DOT11_DRV[1]: set_channel Channel set to 36 [*06/16/2019 19:32:00.8799] DOT11_CFG[0] Radio Mode is changed from Local to Fle xConnect [*06/16/2019 19:32:00.8899] DOT11_DRV[0]: Start Radio0 [*06/16/2019 19:32:00.8899] DOT11_CFG[1] Radio Mode is changed from Local to Fle xConnect [*06/16/2019 19:32:00.8899] DOT11_DRV[1]: Start Radio1 [*06/16/2019 19:32:00.9299] DOT11_DRV[0]: Stop Radio0 [*06/16/2019 19:32:01.1199] DOT11_DRV[0]: set_channel Channel set to 1 [*06/16/2019 19:32:01.1199] DOT11_DRV[0]: Start Radio0 [*06/16/2019 19:32:01.1199] DOT11_DRV[0]: Channel set to 1, width 20 [*06/16/2019 19:32:01.1299] DOT11_DRV[0]: Stop Radio0 [*06/16/2019 19:32:01.3499] DOT11_DRV[0]: Start Radio0 [*06/16/2019 19:32:01.3499] DOT11_DRV[0]: Channel set to 1, width 20 [*06/16/2019 19:32:01.3699] DOT11_DRV[1]: Stop Radio1 [*06/16/2019 19:32:01.3799] DOT11_DRV[1]: set_channel Channel set to 36 [*06/16/2019 19:32:01.3799] DOT11_DRV[1]: Start Radio1 [*06/16/2019 19:32:01.3799] DOT11_DRV[1]: Stop Radio1 [*06/16/2019 19:32:01.6199] DOT11_DRV[1]: Start Radio1 [*06/16/2019 19:32:01.6199] DOT11_DRV[1]: Channel set to 36, width 20 [*06/16/2019 19:32:01.6199] DOT11_DRV[1]: Stop Radio1 [*06/16/2019 19:32:01.6299] DOT11_DRV[1]: Start Radio1 [*06/16/2019 19:32:01.6299] DOT11_DRV[1]: Channel set to 36, width 20 [*06/16/2019 19:32:04.1899] ethernet_port wired0, ip 10.0.5.72, netmask 255.255. 255.0, gw 10.0.5.1, mtu 1500, bcast 10.0.5.255, dns1 10.0.4.2, dns2 10.0.2.2, do main tombstone.k12.az.usAP IPv4 Address updated from 0.0.0.0 to 10.0.5.72 [*06/16/2019 19:32:14.8399] DOT11_CFG[0] Radio Mode is changed from FlexConnect to FlexConnect [*06/16/2019 19:32:14.8599] DOT11_CFG[1] Radio Mode is changed from FlexConnect to FlexConnect [*06/16/2019 19:34:45.7399] chatter: tohost_virtual :: ToHost: device 'virtual' went down [*06/16/2019 19:34:45.7799] chatter: tohost_vlan0 :: ToHost: device 'vlan0' went down [*06/16/2019 19:34:45.8599] chatter: tohost_vlan1 :: ToHost: device 'vlan1' went down [*06/16/2019 19:34:45.9099] chatter: tohost_vlan2 :: ToHost: device 'vlan2' went down [*06/16/2019 19:34:45.9499] chatter: tohost_vlan3 :: ToHost: device 'vlan3' went down [*06/16/2019 19:34:45.9999] chatter: tohost_vlan4 :: ToHost: device 'vlan4' went down [*06/16/2019 19:34:46.0399] chatter: tohost_vlan5 :: ToHost: device 'vlan5' went down [*06/16/2019 19:34:46.1099] chatter: tohost_vlan6 :: ToHost: device 'vlan6' went down [*06/16/2019 19:34:46.1499] chatter: tohost_vlan7 :: ToHost: device 'vlan7' went down [*06/16/2019 19:34:46.2199] chatter: tohost_vlan8 :: ToHost: device 'vlan8' went down [*06/16/2019 19:34:46.2599] chatter: tohost_vlan9 :: ToHost: device 'vlan9' went down [*06/16/2019 19:34:46.3099] chatter: tohost_vlan10 :: ToHost: device 'vlan10' we nt down [*06/16/2019 19:34:46.3699] chatter: tohost_vlan11 :: ToHost: device 'vlan11' we nt down [*06/16/2019 19:34:46.4299] chatter: tohost_vlan12 :: ToHost: device 'vlan12' we nt down [*06/16/2019 19:34:46.4799] chatter: t Cryptographic library self-test.... Testing SHA1 Short Message 1 Testing SHA256 Short Message 1 Testing SHA384 Short Message 1 SHA1 POST PASSED Testing HMAC SHA1 Short Message 1 Testing HMAC SHA2 Short Message 1 Testing HMAC SHA384 Short Message 1 passed! XML config selected /bin/sh: /usr/bin/iptables: not found /bin/sh: /usr/bin/iptables: not found Starting SSHD: ok Validating XML configuration Cisco is a trademark of Cisco Systems, Inc. Software Copyright Cisco Systems, Inc. All rights reserved. Cisco AireOS Version 8.5.140.0 Initializing OS Services: ok Initializing Serial Services: ok Initializing Network Services: ok Starting Statistics Service: ok Starting ARP Services: ok Starting Trap Manager: ok Starting Network Interface Management Services: ok Starting System Services: ok Starting SNMP services: ok Starting Fastpath Hardware Acceleration: Starting Switching Services: ok Starting QoS Services: ok Starting Policy Manager: ok Starting Data Transport Link Layer: ok Starting Access Control List Services: ok Starting System Interfaces: As the Mgmt Address is updated, all the DHCP scopes with Central NAT enabled wil l be disabled and enabled As the Mgmt Address is updated, all the WLANs associated with central NAT enable d scopes will be enabled and disabled ok Starting Client Troubleshooting Service: ok Starting Certificate Database: Initializing Curl Globally.. ok Starting VPN Services: ok Starting Management Frame Protection: ok Starting DNS Services: ok ok Starting LWAPP: ok Starting CAPWAP: ok Starting LOCP: ok Starting Security Services: ok Starting Policy Manager: ok Starting Authentication Engine: ok Starting Mobility Management: ok Starting Capwap Ping Component: ok Starting AVC Services: ok Starting AVC Flex Services: ok Starting Virtual AP Services: ok Starting AireWave Director: ok Starting Network Time Services: ok Starting Cisco Discovery Protocol: ok Starting Broadcast Services: ok Starting Logging Services: ok Starting DHCP Server: ok Starting IDS Signature Manager: ok Starting RFID Tag Tracking: ok Starting RF Profiles: ok Starting Mesh Services: ok Starting TSM: ok Starting CIDS Services: ok Starting Ethernet-over-IP: ok Starting DTLS server: enabled in CAPWAP Starting CleanAir: ok Starting WIPS: ok Starting SSHPM LSC PROV LIST: ok Starting RRC Services: ok Starting SXP Services: ok Starting Alarm Services: ok Starting FMC HS: ok Starting FLEXEXPRESS ConfigSync Task: ok Starting Hotspot Services: ok Starting HTTP Image Download Task: ok Starting Tunnel Services New: ok Starting Portal Server Services: ok Starting Management Services: Web Server: CLI: Secure Web: ok Starting IPSec Profiles component: ok Starting CPU ACL Logging services: ok
