Air Ant2440 and Air Ant5160
matthewlogan46
I have this doubt I can connect the antennas AIR-ANT2440NV-R= and AIR-ANT5160NP-R= in the access points 1262.
Stephen Rodriguez
Both antenna are for indoor AP with RP-TNC connectors. So they should work on the 1262.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/data_sheet_ant5160np.pdf
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/data_sheet_ant2440nv.pdf
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Ok, thank Stephen Rodriguez.
I had saw those data sheets, but I am not sure.
Something additional to add, Cisco will only support antennas up to 7dBi on the 1260. Anything higher will cause the AP to be out of spec for FCC.
__________________________________________________________________________________________
Here is my 2¢
Since these AP's have 6 ports, 3 on each radio, why not use an antenna like this:
http://www.tessco.com/products/displayProductInfo.do?sku=354980
Or if the ceiling isn't so high, something like this:
AIR-ANT2451NV-R=
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
