Got a 1572 AP plugged in getting ready to finish configuring it. It discovered the WLC fine and I changed the AP mode from Bridge to Local so it rebooted. That's where it has gotten stuck. I get as far as the below output and it hasn't changed for over an hour:
IOS Bootloader - Starting system.
flash is writable
40MB format
Cyprus MB -- 40MB of flash
Xmodem file system is available.
flashfs[0]: 24 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 13416448
flashfs[0]: Bytes available: 27742208
flashfs[0]: flashfs fsck took 10 seconds.
I2C bus 1 timed out as busy at line: 291
Cookie read error: -10
get_cookie: read failed
Reading cookie from flash parameter block...done.
get_cookie_hardcopy: cookie checksum error
Invalid parameter block -- no MAC address available.
port 5 Ethernet speed is 1000 Mb - FULL Duplex
Unable to figure out local mac address.
The system has encountered an error initializing the
TFTP file system. The system is ignoring the error and
continuing to boot. If you abort the boot process,
the following commands will set IP_ADDR, DEFAULT_ROUTER
and NETMASK environment variables, initialize the tftp
system, and load the operating system software:
set IP_ADDR
set DEFAULT_ROUTER
set NETMASK
tftp_init
boot
Loading "flash:/c1570-k9w8-mx.153-3.JF10/c1570-k9w8-mx.153-3.JF10"...##############################################
File "flash:/c1570-k9w8-mx.153-3.JF10/c1570-k9w8-mx.153-3.JF10" uncompressed and installed, entry point: 0x1003000
executing...
We have two more of these APs in our environment and haven't had issues with those. Our WLC is running version 8.5.151.0. Thanks for any assistance that can be provided.
