04-12-2017 07:57 AM - edited 07-05-2021 06:51 AM
Need assistance how to configure 1815w AP for POC at customer site , where i got info that i can configure mobility express and test the coverage for a customer . But i dont see an RJ45 Console port and in data sheet and software download i saw only options for light wight IOS available .
No stand alone IOS found for 1815w . I am not getting any correct document how to configure the mobility express for 1815w . Not avalible in you tube as well .Can anybody help me which mobility express software should i download . And how can i configure and do a POC signal strength .
04-12-2017 08:24 AM
I believe the information you need can be found here.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_01101.html
William Kuczmera
04-12-2017 08:52 AM
Hi I have seen steps to convert it for mobility express version from capwap . but i see only those are for 1850 2800 . In the cisco software download for mobility express i cannot see for 1815w mobility express . Do you have any idea whether cisco air 1815w supports mobility express for site survey .
and if supports which software version i have to download .
Also In physical ap i dont see a RJ45 console port , how can i take an console for this access point .
04-12-2017 10:33 AM
The doc I posted earlier suggests this there is a whole chapter on Mobility Express for Site Survey
Cisco 802.11ac Wave 2 access points are capable of running Cisco Mobility Express which a virtual wireless controller function embedded on an Access Point.
Cisco Mobility Express access point running the wireless controller function will also provide wireless connectivity to the clients. It also supports internal DHCP server which enables Access Point to be used for Site Survey.
Access Points–Cisco 802.11ac Wave 2 access points running Cisco Mobility Express software. The following APs support Cisco Mobility Express:
Access Point | Release |
1815I Series | AireOS Release 8.4 and later |
1815W Series | AireOS Release 8.4 and later |
1830 Series | AireOS Release 8.3.111.0 and later |
1850 Series | AireOS Release 8.3.111.0 and later |
3800 Series | AireOS Release 8.3.111.0 and later |
1560 Series | AireOS Release 8.3.111.0 and later |
William Kuczmera
