08-01-2019 07:23 AM - edited 07-05-2021 10:47 AM
Greetings,
I just inherited a small Cisco Aironet wireless network and I am still kinda lost with the different models.
Network is REALLY small, was just two AIR-AP1832I-E-K9C with Cisco Mobility Express running on one of them. Unfortunately the second AP snuffed it and we are looking for a replacement.
Because of the odd building structure (long and narrow) I would rather deploy two smaller APs in that part of the building.
I found that I can get refurbished Cisco AIR-CAP3502I-E-K9 pretty cheap. Can I use them with the Mobility Express and the AP1832 as a master? Or what AP would be recommended? It is just a basic office guest wifi.
Solved! Go to Solution.
08-01-2019 12:56 PM
Yes you can.
Master APs |
Subordinate APs |
Cisco Aironet 1560 Series Cisco Aironet 1815i Cisco Aironet 1815w Cisco Aironet 1830 Series Cisco Aironet 1850 Series Cisco Aironet 2800 Series Cisco Aironet 3800 Series
-If I helped you somehow, please, rate it as useful.- |
Cisco Aironet 700i Series Cisco Aironet 700w Series Cisco Aironet 1600 Series Cisco Aironet 1700 Series Cisco Aironet 1810W Series Cisco Aironet 2600 Series Cisco Aironet 2700 Series Cisco Aironet 3500 Series Cisco Aironet 3600 Series Cisco Aironet 3700 Series
08-01-2019 12:56 PM
Yes you can.
Master APs |
Subordinate APs |
08-05-2019 12:36 AM
Thanks for the list!
