AIR-AP2802I SSH Could Not Be Established
fdharmawan
Level 4
Level 4
Hi Guys,
In my POC environment, there are 5 AIR-AP2802I APs. I just noticed recently that I can't connect to one of them via SSH, while the other is working fine. All the settings are the same, inherited from global config. When I checked via paping, apparently port 22 is not listening/open. Please see attached picture.
Is this some kind of bug? My WLC is 5502 and running on 8.2.166.0.
Thank you
This is what I see in the bug:
Symptom:
* AP is constantly disassociating from the WLC.
* if the AP reboots by itself, it will join back to the controller automatically.
* If the AP does not reboot, console or SSH connections to the AP are not available.
Conditions:
* Normal operations,
Workaround:
* A reboot of the AP momentarily fix the issue
-Scott
Scott Fella
Can be, have you tried rebooting the AP?
-Scott
Take a look at this bug id: CSCvi61741
-Scott
Hi Scott,
I already rebooted the AP several times, no effect. And the bug you attached, the symptom is "1832 stops working when a specific type of Phone is deployed".  No relation to SSH at all.
Symptom:
Conditions:
Workaround:
-Scott
