07-03-2018 09:35 PM - edited 07-05-2021 08:48 AM
Hi Guys,
In my POC environment, there are 5 AIR-AP2802I APs. I just noticed recently that I can't connect to one of them via SSH, while the other is working fine. All the settings are the same, inherited from global config. When I checked via paping, apparently port 22 is not listening/open. Please see attached picture.
Is this some kind of bug? My WLC is 5502 and running on 8.2.166.0.
Thank you
Solved! Go to Solution.
07-04-2018 03:30 AM
07-03-2018 09:39 PM
07-03-2018 09:40 PM
07-03-2018 10:00 PM
Hi Scott,
I already rebooted the AP several times, no effect. And the bug you attached, the symptom is "1832 stops working when a specific type of Phone is deployed". No relation to SSH at all.
07-04-2018 03:30 AM
