Highlighted
Contributor
air-ap3802P-B-K9 with AIR-ANT2513P4M-N antenna
anyone know the exact power consumption for air-ap3802P-B-K9 with AIR-ANT2513P4M-N antenna, it boots up but stuck at 15.4 and does not even show connected on switch port. I have another Meraki MR45 with same class4 which negotiates 30 Watt but not 3802P
Gi1/0/8 auto on 15.4 Ieee PD 4 30.0
Gi1/0/24 auto on 30.0 Meraki MR45 Cloud M 4 30.0
-Rate helpful posts-
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Community Legend
Re: air-ap3802P-B-K9 with AIR-ANT2513P4M-N antenna
That's a potential faulty cable.
Do the following:
1. Command: test cable tdr interface Gi1/0/8;
2. Wait for approximately 5 to 7 seconds for the process to complete;
3. Command: sh cable tdr interface Gi1/0/8; and
4. Post the complete output to #3.
5 REPLIES 5
Highlighted
Power Allocated
Admin Value: 30.0
Power drawn from the source: 30.0
Power available to the device: 30.0
Actual consumption
Measured at the port: 12.7
Maximum Power drawn by the device since powered on: 15.5
If the interface does not show as connected, your problem may not be power. As you can see, this Access Point have been working fine and the maximum power drawn is 15.5.
-If I helped you somehow, please, rate it as useful.-
Highlighted
Contributor
Thanks, this is helpful, would you mind sharing the switch model and version your AP is connected to and the power negotiation used details ?
Highlighted
  Cisco Switch 3650 version 16.3.5
  Access Point 3802E with external antenna AIR-ANT2566D4M.
Highlighted
Do the following:
Highlighted
Contributor
yikes, i should have done a TDR test before all this troubleshooting.
It was cable.
INSIDE-Switch#sh power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 495.0 107.6 387.4
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/8 auto on 30.0 AIR-AP3802P-B-K9 4 30.0
Content for Community-Ad
Cisco COVID-19 Survey
