Highlighted
Beginner
AIR-CAP3502 and smartphone
hello
 i have AIR-CAP3502
with ap3g1-k9w7-xx.153-3.JAB
i set two lan
Radio0-802.11N2.4GHz
and
 Radio1-802.11N5GHz
dhcp is from router
i can connect to it with laptops
but I can not connect to it with a smartphone (galaxy s3 ,galaxy s4, galaxy note 3, galaxy s3 mini)
the smartphone cant even see the AP
I can  connect  with a smartphone to the other simple AP like tplink or level1
Everyone's tags (1)
7 REPLIES 7
Highlighted
Rising star
can you try connecting them
can you try connecting them when authentication method is Open
Highlighted
Beginner
I spoke too soonI have 4 AP1
Highlighted
Beginner
I managed to fix itI forgot
edit
Highlighted
Beginner
I spoke too soon
I have 4 AP
1 dlink
1 level1
1tplink
1cisco
After setting the cisco AP
All devices only connect to it
Even if I am closer to another AP
Highlighted
Beginner
Before I mark Vin Broadcast
Before I mark V
in
Broadcast SSID in Beacon
I could not even see the network
As if the AP does not exist
Highlighted
To broadcast the SSID in the
  1. To broadcast the SSID in the access point beacon, check the Broadcast SSID in Beacon checkbox. When you broadcast the SSID, devices that do not specify an SSID can associate to the access point. This is a useful option for an SSID used by guests or by client devices in a public space. If you do not broadcast the SSID, client devices cannot associate to the access point unless their SSID matches this SSID. Only one SSID can be included in the access point beacon.
  2. (Optional)Check the Enable VLAN ID checkbox and enter a VLAN number (1 through 4095) to assign the SSID to a VLAN. You cannot assign an SSID to an existing VLAN.
  3. (Optional)Check the Native VLAN checkbox to mark the VLAN as the native VLAN.
Highlighted
Beginner
AttachingScreenshots Why do I
Attaching
Screenshots
Why do I need VLAN ?
how do i know what is the VLAN Number i need ?
Content for Community-Ad
