07-10-2015 12:52 PM - edited 07-05-2021 03:33 AM
Deploying some AIR-CAP3702I-A-K9.
They are coming up with medium power (15.4W). Can this be changed or should we use a PWR injector for more power?
07-10-2015 05:16 PM
Apply power to the access point:
a. The access point is 802.3af (15.4 W) compliant and can be powered by any 802.3af-compliant device.
Note The access point is downgraded to 3x3 when it is connected to a 15.4W supply. For the access point to operate at its full potential, using an 802.3at PoE switch or AIR-PWRINJ4 power injector is recommended.
The recommended external power supply for the access point is the Cisco AIR-PWR-B power supply. The access point can also be powered by the following optional external power sources:
– Access point power injector (AIR-PWRINJ5)
– Any 802.3af compliant power injector
07-11-2015 01:30 AM
Depends on the model of your switch.
