Highlighted
Beginner
AIR-CT5760 and ISE as admin authentication server
HEllo
i am trying to setup ISE 1.2 to be radius authentication server for our WLC admins; we have thsi setup for older WLCs no problem but with this new WLC it just not working. Any good document i can follw to setup admin access via radius ISE 1.2?
thanks
4 REPLIES 4
Highlighted
VIP Mentor
If you are trying to control GUI access of these controller (https://x.x.x.x/wireless) via RADIUS, I do not think you can do this.
Since those are IOS based devices, you can restrict CLI access using privilege levels, but not WLC GUI access using RADIUS attributes.
Rasika
**** Pls rate all useful responses. Each time you rate a response Cisco will donate $1 to Kiva ****
Highlighted
Hi Rasika
if this is a IOS device then i should at least be able to use AAA commands to restrict/provide access to admin users - right now if i ssh into cli i can type anything as un/pw (like afdfdsfsdf/fdfdfasd) and i got in into enable mode.
I have routers/switches/asa i configured for AAA no problem. Is behavior of this CT5760 as same as with other Cisco ios devices?
Highlighted
Any ideas?
Highlighted
Please refer to the link-
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/user_guide/ise_user_guide/ise_admin.html
