Highlighted
Beginner
AIR-LAP1041N problem with local switching
In a branch office I have several Lightweigt AP's, a mix of 1041, 1142 and 1602 AP's and a Cisco virtual WLC controller (7.4.121.0)
in the central office. The wlan's are setup as locally switched flexmode.
All the AP's are connected to WS-C3750X-48P (15.0(2)SE5) switches the 1142 and the 1602 work fine but the 1041 doesn't seem to pick up the trunk
interface GigabitEthernet5/0/43
description --- AP  ---
switchport trunk native vlan 201
switchport trunk allowed vlan 201,202-203
switchport mode trunk
spanning-tree portfast trunk
end
On the controller I can see that the LAP1041 has joined but doesn't see the switch as CDP neighbour, the others do.
On the switch you can see the following in CDP neighbour
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
AP-1041          Gig 5/0/46        149              R T   AIR-LAP10 Gig 0.1
AP-1140          Gig 5/0/47        172              R T   AIR-LAP11 Gig 0
For the AP's to work they have to show as "Gig 0" in the cdp neighbour.
Any idea's compatibillity problem with the 3750-X or with IOS 15.0(2)? In the central office LAP1042 connected to old 3750's, IOS 12.2 work fine in Flexmode with local switching
4 REPLIES 4
Highlighted
Hall of Fame Master
Re: AIR-LAP1041N problem with local switching
Have you tried to reset one of those AP's and have it join again to see if it functions properly? That is what I would do because it seems like it's the AP and not your switch.
-Scott
Beginner
Restarted multiple times, native vlan is set on the controller for all 1041 AP's
Highlighted
Hall of Fame Master
No restart the AP, but factory reset the AP... was this working fine before and then you upgraded the vWLC?  Need to understand a bit if this was working prior or not and what has changed.  The only way to see if this is an AP issue is to factory reset and also erase the nvram of the AP so it's like a brand new AP out of the box.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Highlighted
Beginner
It has never worked, this is a new build using some older AP's as we had those lying around still, all AP's were set to defaults using the button prior to being added to the new situation, they "join", the right software is downloaded automatically but they never truely work.
I have seen on post which is kind of similar but that never had an solution
https://supportforums.cisco.com/thread/2106901
Content for Community-Ad
