AIR-LAP1042N-E-K9 %CAPWAP-5-DHCP_RENEW
serdar.bsgn1
               It keeps saying %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP
. Renewing DHCP IP. then nothing happens. I want to turn device defaults and i dont know how.
               I'm using Hyperterminal to access my device.
25 Replies 25
Leo Laohoo
Exactly what are you trying to do/achieve?
Just want to configurate it and use as an Access point thats all
Autonomous or controller-based?
I dont know what means the words you said but it can be a lot of easier if i can just do it like other modems aps etc. On the chrome or another browser i cant do anything with terminal
Autonomous: Standalone AP (Work alone)
Lightweight AP: Only work with Cisco Wireless LAN Controller
This error means, you have a Lightweight AP.
To use it without Controller, you must need to change it to Autonomous
How to convert Lightweight to Autonomous:
1.fllow the procedue on this post.
https://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
After conversion you just need to configure it:
https://rscciew.wordpress.com/2014/05/24/single-ssid-configuration-on-autonomous-ap/
Don't forget to rate helpful posts
I understand what to do but i cant find the image file in the site it says end of sale end of life for my device.
Thank you for your help
To do the conversion you need an autonomous image like
c1140-k9w7-tar.153-3.JBB.tar
The images for the 1040s and 1140s are all called the same and they are available for download on the Cisco page. Just look on the support tab > Download search and look for 1040 Series Access Point and select the autonomous version. I an seeing the page while I type this and it is available for download.
If you have problems with the download and if the device is under contract or warranty, you can open a TAC case and we will provide the image to you. We can even help you out with the conversion if we need to.
Best regards,
Marco Gonzalez
Cisco TAC
OK now I downloaded the tar file and ready to do the things that sandeep told me about lap to aap. I use the codes but I stuck here:
AP2c54.2d19.09eb#debug capwap console cli
Debug already enabled
AP2c54.2d19.09eb#config t
Enter configuration commands, one per line.  End with CNTL/Z.
AP2c54.2d19.09eb(config)#int fa 0
% Invalid input detected at '^' marker.
I used ? for see what code can i use and this showed up
AP2c54.2d19.09eb(config)#int ?
  Async               Async interface
  BVI                 Bridge-Group Virtual Interface
  CDMA-Ix             CDMA Ix interface
  CTunnel             CTunnel interface
  Dialer              Dialer interface
  Dot11Radio          IEEE 802.11 WLAN
  GigabitEthernet     GigabitEthernet IEEE 802.3z
  Group-Async         Async Group interface
  Lex                 Lex interface
  Loopback            Loopback interface
  Multilink           Multilink-group interface
  Null                Null interface
  Tunnel              Tunnel interface
  Vif                 PGM Multicast Host interface
  Virtual-Dot11Radio  Virtual Dot11 Interface
  Virtual-PPP         Virtual PPP interface
  Virtual-Template    Virtual Template interface
  Virtual-TokenRing   Virtual TokenRing
  range               interface range command
now i get stuck again
conf t
interface GigabitEthernet0
you have a 1042 with a GigE port, not a FastEthernet port.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Yes it helped thank you. Now I should do this command and there is an error again
archive download-sw /force-reload /overwrite tftp://10.0.0.1/ c1140-k9w7-tar.153-3.JB.tar,
where should i place this file in my pc? (1140-k9w7-tar.153-3.JB.tar)
it would need to be placed in your TFTP servers root folder.
Steve
HTH,
Steve
If I have made a mistake please correct me but that invalid input again...
Don't keep the space between IP and image name on this command:
archive download-sw /force-reload /overwrite tftp://10.0.0.1/c1140-k9w7-tar.153-3.JB.tar
So i get this error this time.
AP2c54.2d19.09eb#$ad /overwrite tftp://10.0.0.1/c1140-k9w7-tar.153-3.JAB.tar
examining image...
%Error opening tftp://10.0.0.1/c1140-k9w7-tar.153-3.JAB.tar (Socket error)
archive download: takes 0 seconds
