Air-lap1042N-E-K9 Lightweight to Autonomous ?
Yu_Celzi_
hello,
I have a air-lap1042-n-e-k9, how to put this wi-fi mode autonomous ?
5 Replies 5
Alex Mac
Hi Daniel,
this old thread may be useful
https://supportforums.cisco.com/thread/2006044
Alex
Thanks Alessandro,
I use a POE switch, because I don't external power ...
What to do?
Same thing.  You can disconnect the ethernet cable to power off the WAP or you can use the command in the interface-level "no power inline" or "power inline never" to disable power to the port.
I did as in the link but its not working ...
Can you give me more explication.
1.  Connect the WAP into, say, port 1 of the Cisco switch.
2.  Connect the TFTP server to say, port 2 on the Cisco switch.
3.  Make sure they are on the same VLAN, VLAN 1, for example.
4.  In the switch, configure this:
conf t
interface f0/1
power inline never
5.  Hold down the WAP's "mode" button
6.  Back to the switch, enter the command:  no power inline never
7.  Keep holding the mode button until it'll say something like "waiting for the mode button to be released" or something.
