AIR-LAP1242AG-A-K9 Cannot Join to WLC
arika_wahyono
Guys,
I have problem, i try to connect AP AIR-LAP1242AG-A-K9 to WLC 4400 with Software 7.0.98.218, but the AP indicator is blink and always request new IP addres (based on AP logg console), this device can ping from LAN but unstable (based on logg, the AP always request new IP Address).
anyone have any had same experience with this case?
This is log when i try console to AP.
Xmodem file system is available.
flashfs[0]: 15 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 10084864
flashfs[0]: Bytes available: 5914112
flashfs[0]: flashfs fsck took 36 seconds.
Base ethernet MAC Address: 00:1d:45:36:86:ca
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1240-k9w8-mx.124-23c.JZ/c1240-k9w8-mx.124-23c.JZ"...########################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1240-k9w8-mx.124-23c.JZ/c1240-k9w8-mx.124-23c.JZ" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1240 Software (C1240-K9W8-M), Version 12.4(23c)JZ, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 06-Apr-11 15:01 by prod_rel_team
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 15 files, 4 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15740928
flashfs[1]: Bytes used: 10084864
flashfs[1]: Bytes available: 5656064
flashfs[1]: flashfs fsck took 5 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 7100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 25590K/7168K bytes of memory.
Processor board ID FTX1135B3ZF
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
LWAPP image version 7.0.98.218
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: xxxxxxxxxx
Part Number                          : 73-9925-06
PCA Assembly Number                  : 800-26579-05
PCA Revision Number                  : xxxxx
PCB Serial Number                    : xxxxxxx
Top Assembly Part Number             : xxxxxxx
Top Assembly Serial Number           : xxxxxxx
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-A-K9
% Please define a domain-name first.
Press RETURN to get started!
*Mar  1 00:00:06.526: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.150: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:09.747: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:09.863: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages)
*Mar  1 00:00:09.895:  status of voice_diag_test from WLC is false
*Mar  1 00:00:12.004: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:12.072: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:12.072: %SNMP-5-COLDSTART: SNMP agent on host AP001d.4536.86ca is undergoing a cold start
*Mar  1 00:00:12.154: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:00:12.161: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:12.161: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:12.369: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:13.016: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Mar  1 00:00:13.170: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:00:13.170: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:00:20.493: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:00:30.976:  status of voice_diag_test from WLC is false
*Mar  1 00:00:31.083: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:34.263: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:34.304: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:34.342: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:35.265: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:00:35.265: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:35.304: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.tester.net"...domain server (10.10.10.40)
Translating "CISCO-LWAPP-CONTROLLER.tester.net"...domain server (10.10.10.40)
*Mar  1 00:00:42.131: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:42.135: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:00:42.139: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:01:32.143: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:01:34.274: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
Not in Bound state.
*Mar  1 00:01:40.659: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:01:40.778: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:01:48.652: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:48.655: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:01:48.657: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:02:28.661: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:02:37.173: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:02:37.290: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxx.xxxx
*Mar  1 00:02:45.164: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:45.167: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:02:45.169: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:03:25.170: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:03:33.681: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:33.798: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:03:41.673: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:03:41.676: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:03:41.678: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:04:21.679: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:04:30.191: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:04:30.308: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:04:38.181: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:04:38.184: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:04:38.187: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER.tester.net
*Mar  1 00:05:18.191: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
Not in Bound state.
*Mar  1 00:05:26.703: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:05:26.820: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.10.11.150, mask 255.255.255.0, hostname AP001d.xxxx.xxxx
*Mar  1 00:05:34.694: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:05:34.696: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.tester.net
*Mar  1 00:05:34.699: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROL
Thanks!!!
3 Accepted Solutions
Hi Arika,
If your WLC mgt vlan is not DHCP enable, yes you can try manually configure an IP like below (IP & Gateway & WLC mgt IP info you have to change to according to your IP scheme). If CAPWAP keyword does not work uses LWAPP keyword in the command syntax
LWAP#debug capwap console cli
LWAP#capwap ap ip address 10.10.110.5 255.255.255.0
LWAP#capwap ap ip default-gateway 10.10.110.1
LWAP#capwap ap controller ip address 10.10.110.10
LWAP#debug lwapp console cli
LWAP#lwapp ap ip address 10.10.110.5 255.255.255.0
LWAP#lwapp ap ip default-gateway 10.10.110.1
LWAP#lwapp ap controller ip address 10.10.110.10
Refer this for more details
http://mrncciew.com/2013/03/17/ap-registration/
Post the AP console output this time if that does not work
Rasika
**** Pls rate all useful responses ****
Can you try to factory default the AP and don't use a static.
Here are a few ways to factory default. Try LWAPP first and then if that doesn't take then CAPWAP
erase /all nvram
Example:
Entered the username and password
erase /all nvram:
[confirm]
undebug all
reload
[confirm]
Hold reset for over 30 seconds to get to ROMMON
ap:delete flash:private-config
ap:delete flash:private-multiple-fs
ap:boot
Your AP will be factory default
-Scott
Dear Team,
My AP has associate with the wlc, all i do is reset and reset AP to factory default, and then i assign static ip address and now the AP has discover from wlc and then i change the static to dhcp and everything going normally.
this step has been done before but failed.
Thanks for support!!
Arik
30 Replies 30
Hi Arika,
Try to put the AP onto the same vlan as WLC management IP address.Then if it register, later on you can re-connect the AP whereever you wanted with any other vlan configuration.
Looks like AP cannot learn about WLC
Rasika
Hi Rasika,
did you mean i should configure static ip address for this AP? and then i reconfigure this ap to use ip dhcp?
Hi Arika,
Rasika
Hi Rasika,
did this problem because Policy Configuration? because on my WLC only use self-signed certs (SSCs).
btw,
is it problem when i use vlan  WLC to assign ip address to AP? because other AP not same vlan with WLC, i mean that configuration not impact to existing AP.
Arik
No, there should be a way to AP to learn about WLC IP. It can be either layer 3 broadcast, DNS, DHCP option 43 or statically configured. Since you have not setup any of those (as per the AP log we can tell it does not know what is WLC IP & that's why it is keep rebooting), I have requested you to configure it statically & see. If a AP register for a controller it will remember that WLC IP & alway search for it as long as it has L3 reachability to your WLC.
AP does not need to be on same vlan as WLC. But if you put on the same vlan, then via L3 broadcast AP will find the controller IP. (so you do not want to configure statically in this case). That's a easy test to see if there is any other issue why AP cannot register to a WLC. If that register you can put AP back to where it was, it is only for testing we are doing it.
It won't impact any other APs if those already register to WLC.
Rasika
Dear Rasika,
I forgot, that before i reset this AP, this AP has detect by WLC but with static IP Address.
reason for the reset because AP with different vlan.
So, we can say that AP has been detected by WLC before,
now, what should i do? should i configure this AP with static IP Address?
Arik
I try your post to assign static ip address, but the result is same, the AP still not discover from WLC.
sorry, update, not work... , but before the AP is discover with static ip address
we use dhcp server with dedicated server, not dhcp from switch or router.
Thxs,
Connect the AP to the same Vlan as the WLC management IP address. Make sure that when the AP boots up, that it gets a DHCP address, so this means the subnet needs to have a valid DHCP scope to hand out IP address. This is the easiest way
For the AP to join... Same layer 2 network.
The management and ap-manager if the WLC should be on the same subnet to.
-Scott
Hai Scott,
I had config static ip address for this AP with same vlan with WLC, but still not work,
I try debug the AP, this is the message:
TEST#debug lwapp client error
LWAPP Client ERROR display debugging is on
TEST#debug lwapp client eve
TEST#debug lwapp client event
LWAPP Client EVENT display debugging is on
TEST#
TEST#debug lwapp client pack
TEST#debug lwapp client packet
LWAPP Client PACKET display debugging is on
TEST#
TEST#
TEST#
TEST#
*Mar  1 01:45:24.237: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 01:45:24.237: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Mar  1 01:45:24.237: LWAPP_CLIENT_EVENT: spamSendDiscoveryRequest: sending discovery type 1 to
x.x.x.x
*Mar  1 01:45:24.237: Sent Msg Type   :   DISCOVERY_REQUEST
*Mar  1 01:45:24.237: Msg Length     :   21
debug lwapp client packet SeqNum     :   0
TEST#
TEST#
TEST#debug lwapp client conf
TEST#debug lwapp client config
LWAPP Client config display debugging is on
TEST#
TEST#
TEST#
*Mar  1 01:45:37.237: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 01:45:37.237: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Mar  1 01:45:37.237: LWAPP_CLIENT_EVENT: spamSendDiscoveryRequest: sending discovery type 1 to
x.x.x.x
*Mar  1 01:45:37.237: Sent Msg Type   :   DISCOVERY_REQUEST
*Mar  1 01:45:37.237: Msg Length     :   21
*Mar  1 01:45:37.237: Msg SeqNum     :   0
*Mar  1 01:45:50.237: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 01:45:50.237: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Mar  1 01:45:50.237: LWAPP_CLIENT_EVENT: spamSendDiscoveryRequest: sending discovery type 1 to
x.x.x.x
*Mar  1 01:45:50.237: Sent Msg Type   :   DISCOVERY_REQUEST
*Mar  1 01:45:50.237: Msg Length     :   21
*Mar  1 01:45:50.237: Msg SeqNum     :   0
*Mar  1 01:46:03.237: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 01:46:03.237: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Mar  1 01:46:03.237: LWAPP_CLIENT_EVENT: spamSendDiscoveryRequest: sending discovery type 1 to
x.x.x.x
*Mar  1 01:46:03.237: Sent Msg Type   :   DISCOVERY_REQUEST
*Mar  1 01:46:03.237: Msg Length     :   21
*Mar  1 01:46:03.237: Msg SeqNum     :   0
*Mar  1 01:46:16.237: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 01:46:16.237: LWAPP_CLIENT_EVENT: spamResolveStaticGateway  - gateway found
*Mar  1 01:46:16.237: LWAPP_CLIENT_EVENT: spamSendDiscoveryRequest: sending discovery type 1 to x.x.x.x
*Mar  1 01:46:16.237: Sent Msg Type   :   DISCOVERY_REQUEST
*Mar  1 01:46:16.237: Msg Length     :   21
*Mar  1 01:46:16.237: Msg SeqNum     :   0
with x.x.x.x is the ip address of AP,
Arik
erase /all nvram
Example:
erase /all nvram:
[confirm]
undebug all
reload
[confirm]
ap:boot
-Scott
Hi Scott,
Still no luck,
after i reboot this is messagefrom AP,
%DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address x.x.x.x, mask 255.255.255.0, hostname TEST
Translating "CISCO-LWAPP-CONTROLLER.zzzz.zzzzz.net"...domain server (x.x.x.x)
%LWAPP-3-CLIENTEVENTLOG: Did not get vendor specific options from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Did not get log server settings from DHCP.
%LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CISCO-LWAPP-CONTROLLER.
zzzz.zzzzz.net
%LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolve CISCO-LWAPP-CONTROLLER.i
zzzz.zzzzz.net
TEST#
TEST#
TEST#
TEST#
TEST#
TEST#
*Mar  1 00:04:59.685: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 00:05:09.685: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 00:05:19.685: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 00:05:29.685: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
*Mar  1 00:05:39.684: LWAPP_CLIENT_EVENT: spamHandleDiscoveryTimer: Could not discover any MWAR
Thxs,
Arik
HI Arik,
First of all paste the output of these commands:
From WLC: sh sysinfo
From AP: sh version
From WLC: debug lwapp events enable
Take care:
Make sure the date and time on the controller is accurate.
Hi Sandee,
This is your request, but without "debug lwapp events enable"
because i worry this is will impact to network and user has been connected to network.
WLC:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.0.98.218
RTOS Version..................................... 7.0.98.218
Bootloader Version............................... 4.0.206.0
Emergency Image Version.......................... 5.2.157.0
Build Type....................................... DATA + WPS
System Name...................................... IDMAN
System Location.................................. Jakarta, Indonesia
System Contact................................... Agus Kurniwanto
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.3
IP Address....................................... X.X.X.X
System Up Time................................... 392 days 8 hrs 36 mins 36 secs
System Timezone Location......................... (GMT +7:00) Saigon, Hanoi, Bangkok, Jakatar
Configured Country............................... US  - United States
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
State of 802.11b Network......................... Enabled
--More-- or (q)uit
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 5
Number of Active Clients......................... 28
Burned-in MAC Address............................ 00:1D:70:20:6C:60
Crypto Accelerator 1............................. Absent
Crypto Accelerator 2............................. Absent
Power Supply 1................................... Absent
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 100
AP:
TEST>SH VER
Cisco IOS Software, C1240 Software (C1240-RCVK9W8-M), Version 12.4(10b)JDA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 30-Oct-08 12:05 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.3(7)JA1, RELEASE SOFTWARE (fc1)
TEST uptime is 1 minute
System image file is "flash:/c1240-rcvk9w8-mx/c1240-rcvk9w8-mx"
export@cisco.com.
cisco AIR-LAP1242AG-A-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
LWAPP image version 3.0.51.0
Base ethernet MAC Address: 00:1D:45:36:86:CA
PCA Revision Number                  : A0
PCB Serial Number                    : Fxxxxxxxxx
Top Assembly Part Number             : 800-29151-02
Top Assembly Serial Number           : Fxxxxxxxxxx
Configuration register is 0xF
Thxs,
Arik
Sorry for last posts, that was misread.
I do not understand that your WLC in domain of Ameriaca and this is in Indonasia.
Timezone is also for bankong.
Doiman of WLC and AP mataches because both have the correct domain.
