02-19-2015 04:06 AM - edited 07-05-2021 02:32 AM
We have a Cisco Aironet 1130AG Access Point in our Community Centre.
It was originally installed by the County Council, with no security password set.
We were unable to access the AP as the technician who installed it had changed the password from the default, but hadn't recorded it (and has now left).
We therefore did a Factory Reset, which has enabled us to configure the AP. However, there are a few problems:
1) If the AP is re-booted, it loses all the settings;
2) We can't save the Current Startup Configuration;
3) We don't seem to be able to change the default password.
Adrian Cobley
02-19-2015 07:13 PM
Is the service compress-config , enabled?
02-20-2015 02:17 AM
Where would I find that?
I can't see it under the list of Services.
02-20-2015 05:21 AM
Normal once you factory default an ap you can do all those commands ... Can you post the config ?
02-20-2015 11:36 AM
Where do I find that?
02-20-2015 05:50 AM
The fact that you can't save the configuration or that it gets deleted after a reboot, points to an issue with the nvram, it might be a hardware failure.
However as George said, paste the configuration to take a look, also issue a show ver and let us know which version are you using.
02-20-2015 11:38 AM
How do I issue a show ver?
02-20-2015 11:47 AM
Are you able to get Telnet access, or do a console connection to the AP?
02-20-2015 12:00 PM
I should be able to do Telnet session. Probably have to wait until tomorrow as it's dinner time in the UK!
02-20-2015 12:01 PM
Sorry, should have said can you give me the run down of what I need to do then!
