Highlighted
Beginner
Aironet 1130AG is not contacting DHCP Server
The Aironet will not hand out an IP address, I have set another DHCP server and no luck, the laptops get an error message Limited or no connectivity, I'm using LDAP and cert for authentication, is there some setting that needs to turned on to pass DHCP traffic?
3 REPLIES 3
Highlighted
Beginner
Hi there,
can you see mobility network-id command under the SSID?? if its there than apply no mobility network-id ................
Highlighted
Thanks for the help!
This is under the Security: Global SSID Manager Correct?
under the Network ID: it is blank.
Highlighted
Enthusiast
give us the show tech from the AP whenn clients are failing...
If runninng lightweight please give us more details.
security type, eap method, server, association table.. etc...
Content for Community-Ad
