Beginner
Aironet 1131AG setup with 3560 switch
I'm having issues trying to setup an Aironet 1131AG with DSL internet service.  I have the Aironet 1131AG connected to a Cisco 3560 8-port POE switch, but can't get internet connection when connected wirelessly.  I enabled DHCP on the Aironet and get assigned an IP, but that's as far as it gets.  I can get internet connection if I plug directly into the switch and I can ping external addresses from the command prompt of the Aironet 1131AG, but no service when connecting a device wirelessly.  Devices connect successfully to the Aironet, but nothing else.
I was wondering if someone could point me in the right direction on setting this up?  Also, can I get by with dhcp on the aironet or do I need a router?  The switch and aironet have static IPs in the same subnet.  I need the simplest way to get internet connection, since it will be for guest.
Here's my current configs:
DSL Service Name Server
222.22.222.185
222.22.222.186
222.22.222.187
DSL Modem IP
333.333.333.113
Cisco 3560 8-port POE Switch
333.333.333.114
Cisco Aironet 1131AG
333.333.333.118
CISCO 3560 8-port POE Switch Configs
Switch Configs
Current configurations : 1101 bytes
version 12.2
no service pad
hostname SAMPLEWIFI
boot-start-marker
boot-end-marker
enable secret 5 $343$353564234
enable password xxxxxxxxxx
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
ip name-server 222.22.222.185
ip name-server 222.22.222.186
ip name-server 222.22.222.187
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
interface Vlan1
ip address 333.333.333.114 255.255.255.0
ip default-gateway 333.333.333.113
ip classless
ip route 333.333.333.0 255.255.255.0 333.333.333.113
ip http server
control-plane
line con 0
line vty 0 4
password xxxxxxxxx
login
line vty 5 15
password xxxxxxxxxx
login
end
CISCO AIRONET 1131AG Configs
Aironet Configs
version 12.4
no service pad
service password-encryption
hostname SampleWIFI
enable secret 5 $$$$$$xxxxxxx
no aaa new-model
clock timezone -0600 -6
ip domain name samplewifi
no ip dhcp use vrf connected
ip dhcp excluded-address 333.333.333.21 333.333.333.255
ip dhcp pool samplepool
  network 333.333.333.0 255.255.255.0
  default-router 333.333.333.113
  lease 3 23
dot11 syslog
dot11 ssid SAMPLEWIFI
  vlan 1
  authentication open
  guest-mode
dot11 network-map
dot11 arp-cache
username xxxxx password 8 2423423423423
bridge irb
interface Dot11Radio0
no ip address
no ip address
ssid SAMPLEWIFI
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid SAMPLEWIFI
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
bridge-group 1
interface BV1
ip address 333.333.333.118 255.255.255.0
no ip route route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Everyone's tags (3)
2 REPLIES 2
Highlighted
Beginner
Not sure if the 3560 image you're working with has it, but try enabling the DHCP service on the 3560.  "Service DHCP" I think.  Don't have one handy so can't give you the syntax.  Also, is the DHCP server on a different VLAN than your clients?  If so, you'll need a DHCP helper configured on the L3 VLAN interface that the clients are on, pointing to your DHCP server's IP address.
Highlighted
Beginner
Hello Shawn,
Take a look at the link below. This configuration is in the 1131AG section and should help you set up the AP and the switch. I personally like to have the DHCP server on the switch rather than the AP to centralize assignment of IP and troubleshooting.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml
To set up the DHCP server on the 3560, use the following commands:
ip dhcp pool data-pool
   import all
   network xx.xx.xx.0 255.255.255.0
   default-router xx.xx.xx.xx
   domain-name domain.local
   dns-server xx.xx.xx.xx
If you like to exclude IP addresses from the pool use:
ip dhcp excluded-address 10.1.1.200 10.1.1.254 (example)
Removing the DHCP server from the AP and configuring the service on the switch should help you isolate the issue further. If the wireless clients obtains an IP address from the switch, then the clients should be able to reach the internet.
Question:
1. Is the DSL modem acting as a router? If so, is the DHCP enabled on it? Disable it and let the switch be the DHCP server.
Hope this helps.
Bert Wilhelm
Content for Community-Ad
